Aller au contenu principal
Lenovo S20-30 Keyboard Replacement
Ce dont vous avez besoin
  1. Lenovo S20-30 Keyboard Replacement, Battery: étape 1, image 1 de 1
    • Flip the Lenovo S20-30 over so that the bottom panel is facing upward.
  2. Lenovo S20-30 Keyboard Replacement: étape 2, image 1 de 1
    • Slide the manual battery latch to the unlock position, so that the red is showing.
  3. Lenovo S20-30 Keyboard Replacement: étape 3, image 1 de 2 Lenovo S20-30 Keyboard Replacement: étape 3, image 2 de 2
    • Slide and hold the spring-loaded battery latch on the other side (right) while sliding the battery out of the computer.
    • Grab new Lenovo S20-30 battery for replacement.
  4. Lenovo S20-30 Keyboard Replacement, Keyboard: étape 4, image 1 de 3 Lenovo S20-30 Keyboard Replacement, Keyboard: étape 4, image 2 de 3 Lenovo S20-30 Keyboard Replacement, Keyboard: étape 4, image 3 de 3
    • Remove the two front rubber feet using a long metal spudger.
    • Use your Phillips #0 screwdriver to remove the two M2.5 x 5mm flat-head screws located underneath the pads.
  5. Lenovo S20-30 Keyboard Replacement: étape 5, image 1 de 1
    • Use the Phillips #0 screwdriver to remove the nine M2 x 4mm flat head screws located on the outer edges on the back of the laptop.
    • Make sure to keep these screws separated from future screws that will be disassembled throughout this process.
  6. Lenovo S20-30 Keyboard Replacement: étape 6, image 1 de 2 Lenovo S20-30 Keyboard Replacement: étape 6, image 2 de 2
    • Use the long metal spudger to pry open the bottom half of the laptop.
    • Gently lift the cover off to reveal the motherboard.
  7. Lenovo S20-30 Keyboard Replacement: étape 7, image 1 de 2 Lenovo S20-30 Keyboard Replacement: étape 7, image 2 de 2
    • Remove the four M2 x 3mm flat-head screw using a Phillips #000 screwdriver.
  8. Lenovo S20-30 Keyboard Replacement: étape 8, image 1 de 2 Lenovo S20-30 Keyboard Replacement: étape 8, image 2 de 2
    • Flip over laptop and open the lid to have access to the keyboard.
    • Use a plastic opening tool to pry apart the keyboard.
  9. Lenovo S20-30 Keyboard Replacement: étape 9, image 1 de 3 Lenovo S20-30 Keyboard Replacement: étape 9, image 2 de 3 Lenovo S20-30 Keyboard Replacement: étape 9, image 3 de 3
    • A connector is attached to the keyboard.
    • Remove it by gently pulling it outward.
  10. Lenovo S20-30 Keyboard Replacement: étape 10, image 1 de 1
    • Grab replacement keyboard to insert back into place.
3 autres ont terminé cette réparation.
ILEANISSE SOTO
Membre depuis le 10/01/18
187 Réputation
1 tutoriel rédigé
Équipe
McKendree University, Team S1-G4, Quinn Fall 2018 Membre de l'équipe McKendree University, Team S1-G4, Quinn Fall 2018
MCKU-QUINN-F18S1G4
2 membres
3 tutoriels rédigés
Un commentaire
where can i find a replacement keyboard/ or what model # do i need?
ed paz - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 6
30 derniers jours : 14
Total : 1,218
