Aller au contenu principal
Lenovo Tab 2 A10-70 Front Glass and Digitizer Replacement
Ce dont vous avez besoin
  1. Lenovo Tab 2 A10-70 Front Glass and Digitizer Replacement, Remove rear casing: étape 1, image 1 de 2 Lenovo Tab 2 A10-70 Front Glass and Digitizer Replacement, Remove rear casing: étape 1, image 2 de 2
    • It is extremely easy to remove the plastic casing. Just slide your spudger (or fingernail if they are strong) around the edge to remove
    A good starting point could be the charging port.
    lassedollerup - Réponse
  2. Lenovo Tab 2 A10-70 Front Glass and Digitizer Replacement, detatch the old digitizer cable: étape 2, image 1 de 1
    • Using your fingernail or tweezers lift the holding flap and disconnect the digitizer cable for the old screen
  3. Lenovo Tab 2 A10-70 Front Glass and Digitizer Replacement, Removing the old Broken Glass/Digitizer: étape 3, image 1 de 3 Lenovo Tab 2 A10-70 Front Glass and Digitizer Replacement, Removing the old Broken Glass/Digitizer: étape 3, image 2 de 3 Lenovo Tab 2 A10-70 Front Glass and Digitizer Replacement, Removing the old Broken Glass/Digitizer: étape 3, image 3 de 3
    • Please be very careful!, This glass shatters easily and shards will go flying if you are rough
    • The glass is connected to the frame and LCD by the world's strongest adhesive, .... took me well over an hour to remove the old screen
    • Using a heat gun (high powered blow dryer) or those of you lucky enough to have an iopener kit slowly heat your way around the glass, start in a corner and work your spudger in.
    • Make sure you slide your spudger straight in to avoid the lcd There is a nice gap but the adhesive is two part!
    What is the cost of the glass screen
    sumanthgouda21 - Réponse
    • Clean your Edges
    • Using your spudger or a razor knife clean off any left behind adhesive
  4. Lenovo Tab 2 A10-70 Front Glass and Digitizer Replacement, Install new Glass/Digitizer: étape 5, image 1 de 2 Lenovo Tab 2 A10-70 Front Glass and Digitizer Replacement, Install new Glass/Digitizer: étape 5, image 2 de 2
    • Carefully Slide the digitizer cable through the opening in the case
    • Flip over case and reconnect the new digitizer cable
    • I then tested to make sure the screen and digitizer worked before adhesive :)
  5. Lenovo Tab 2 A10-70 Front Glass and Digitizer Replacement, Adhere your new screen: étape 6, image 1 de 2 Lenovo Tab 2 A10-70 Front Glass and Digitizer Replacement, Adhere your new screen: étape 6, image 2 de 2
    • The Screen I ordered came with adhesive already on it, but I added some 3M tape too
    • Press the Screen firmly into place
    • Then replace the back cover!
  6. Lenovo Tab 2 A10-70 Front Glass and Digitizer Replacement, Finish!: étape 7, image 1 de 1
    • Test your work and Be proud, not an easy task but you completed it!!!!
18 autres ont terminé cette réparation.
Amber Wooldridge
Membre depuis le 12/09/15
539 Réputation
1 tutoriel rédigé
9 commentaires
Hi Amber,
Thank you for the guide.
How's the replacement screen quality? Can I know where you bought the screen from? I need to replace my screen. Thinking of buying it from the same supplier. Would want a screen with adhesive too.
Thanks
Richard.
richardeugenio - Réponse
I don't quite know but it looks like a regular bootleg one
Sergio Palacio -
I just completed this, using a proper heat Gun it took about 10 minutes.
Ebay screen, oem tagged, apparently no adhesive on it.
Philip Wiberg - Réponse
I love the guide and you have encouraged me to try to replace my screen. Where did you order the replacement screen and did you order just the new glass?
Thanks,
Jack
Jack Wilson - Réponse
did you replace the glass/digitiser only, or did you also replace the lcd ? the title suggests glass/digitiser but step 6 refers to a "new screen" sorry for the confusion
karmatosednz - Réponse
++https://youtu.be/etxKSTK3Gno?t=8m19s++
Is that black tape important? I wasn't lucky and it was torn.
voneout - Réponse
I have more of a question, But first I want to say THANK YOU !!!!, I was diagnosed with a “rare” form of advanced MS, so that ended my 20+ years of being an auto (anything) DC TECH,to a halt, BUT I still can do all of my own repairs, now handy capped, but I always find a way to make up for what ever is in my way. Any way my screens are all good, but after repairing the micro USB I then found I removed the tracer “harness” the wrong way, before I order a new main board, do you have any tips or trix?
Rich K,……primaryms@aol.com THANX A TON!!
Rich K - Réponse
Hi!! Please, I am looking for a replacement screen for mi Lenovo Tab 2, A1070. Does anybody know where can I buy one?? I can’t get it here in Peru. Sorry about my English.
Ana - Réponse
Thanks for the guide. We are having an issue after reassembly where all touch responses are on the opposite side of the screen to where the button is located. Any ideas as to what would be causing this issue?
Shane - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 17
Total : 42,710
