Aller au contenu principal
Lenovo Tab 2 A7-20F Battery Replacement
Ce dont vous avez besoin
  1. Lenovo Tab 2 A7-20F Battery Replacement, Case: étape 1, image 1 de 2 Lenovo Tab 2 A7-20F Battery Replacement, Case: étape 1, image 2 de 2
    • Starting at any point along the seam of the case carefully pry it open with the metal spudger, slowly working your way around the outside until the case can come apart.
  2. Lenovo Tab 2 A7-20F Battery Replacement, Battery: étape 2, image 1 de 2 Lenovo Tab 2 A7-20F Battery Replacement, Battery: étape 2, image 2 de 2
    • The battery is connected to the motherboard by the thin wire shown here.
    • Pull up gently on the yellow tape to access the connector.
  3. Lenovo Tab 2 A7-20F Battery Replacement: étape 3, image 1 de 1
    • Gently detach the connector from the motherboard by pulling up on it.
  4. Lenovo Tab 2 A7-20F Battery Replacement: étape 4, image 1 de 3 Lenovo Tab 2 A7-20F Battery Replacement: étape 4, image 2 de 3 Lenovo Tab 2 A7-20F Battery Replacement: étape 4, image 3 de 3
    • There is double-sided tape inside the case.
    • Use the spudger tool to loosen the bond of the adhesive from the double sided tape.
    • Separate the battery from the case.
2 autres ont terminé cette réparation.
Thanh
Membre depuis le 09/21/17
345 Réputation
3 tutoriels rédigés
Équipe
Washington State, Team S5-G111, Phelps-Hillen Fall 2017 Membre de l'équipe Washington State, Team S5-G111, Phelps-Hillen Fall 2017
WSU-PHELPS-HILLEN-F17S5G111
4 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 6
30 derniers jours : 23
Total : 2,978
