Aller au contenu principal
Lenovo Tab 4 8 Front Camera Replacement
Ce dont vous avez besoin
  1. Lenovo Tab 4 8 Front Camera Replacement, Battery: étape 1, image 1 de 3 Lenovo Tab 4 8 Front Camera Replacement, Battery: étape 1, image 2 de 3 Lenovo Tab 4 8 Front Camera Replacement, Battery: étape 1, image 3 de 3
    • Start at the microSD slot.
    • Use the opening pick to slide underneath the back cover of the tablet.
    • Slide the opening pick around the tablet until the back cover is off.
  2. Lenovo Tab 4 8 Front Camera Replacement: étape 2, image 1 de 3 Lenovo Tab 4 8 Front Camera Replacement: étape 2, image 2 de 3 Lenovo Tab 4 8 Front Camera Replacement: étape 2, image 3 de 3
    • Remove the 8 screws with a Phillips #000 screwdriver [bit].
    • There is a screw under the blue "s" sticker.
    • Remove tape holding plate down.
    • Use precision tweezers or your fingers to remove plate.
  3. Lenovo Tab 4 8 Front Camera Replacement: étape 3, image 1 de 2 Lenovo Tab 4 8 Front Camera Replacement: étape 3, image 2 de 2
    • Remove yellow tape.
    • Use a spudger or plastic opening tool to remove the battery's ribbon cable from the motherboard.
  4. Lenovo Tab 4 8 Front Camera Replacement: étape 4, image 1 de 3 Lenovo Tab 4 8 Front Camera Replacement: étape 4, image 2 de 3 Lenovo Tab 4 8 Front Camera Replacement: étape 4, image 3 de 3
    • Gently pull on the two stretch release adhesive strips. Do not pull up, pull away from battery.
    • Once the tabs are off, lift the battery up from the frame.
    • Do not bend or puncture the battery.
  5. Lenovo Tab 4 8 Front Camera Replacement, Front Camera: étape 5, image 1 de 2 Lenovo Tab 4 8 Front Camera Replacement, Front Camera: étape 5, image 2 de 2
    • Using tweezers, lift the yellow tape hiding the front camera.
    • Disconnect the front camera's connector from the motherboard using tweezers.
Ivan Chavez
Membre depuis le 02/06/19
776 Réputation
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 702
