Aller au contenu principal
Lenovo Tab 4 TB-8504F Motherboard Replacement
Ce dont vous avez besoin
  1. Lenovo Tab 4 TB-8504F Motherboard Replacement, Battery: étape 1, image 1 de 3 Lenovo Tab 4 TB-8504F Motherboard Replacement, Battery: étape 1, image 2 de 3 Lenovo Tab 4 TB-8504F Motherboard Replacement, Battery: étape 1, image 3 de 3
    • Start at the microSD slot.
    • Use the opening pick to slide underneath the back cover of the tablet.
    • Slide the opening pick around the tablet until the back cover is off.
  2. Lenovo Tab 4 TB-8504F Motherboard Replacement: étape 2, image 1 de 3 Lenovo Tab 4 TB-8504F Motherboard Replacement: étape 2, image 2 de 3 Lenovo Tab 4 TB-8504F Motherboard Replacement: étape 2, image 3 de 3
    Outil utilisé dans cette étape :
    J'achète
    • Remove the 8 screws with a Phillips #000 screwdriver [bit].
    • There is a screw under the blue "s" sticker.
    • Remove tape holding plate down.
    • Use precision tweezers or your fingers to remove plate.
  3. Lenovo Tab 4 TB-8504F Motherboard Replacement: étape 3, image 1 de 2 Lenovo Tab 4 TB-8504F Motherboard Replacement: étape 3, image 2 de 2
    • Remove yellow tape.
    • Use a spudger or plastic opening tool to remove the battery's ribbon cable from the motherboard.
  4. Lenovo Tab 4 TB-8504F Motherboard Replacement: étape 4, image 1 de 3 Lenovo Tab 4 TB-8504F Motherboard Replacement: étape 4, image 2 de 3 Lenovo Tab 4 TB-8504F Motherboard Replacement: étape 4, image 3 de 3
    • Gently pull on the two stretch release adhesive strips. Do not pull up, pull away from battery.
    • Once the tabs are off, lift the battery up from the frame.
    • Do not bend or puncture the battery.
  5. Lenovo Tab 4 TB-8504F Motherboard Replacement, MicroSD Card Reader: étape 5, image 1 de 2 Lenovo Tab 4 TB-8504F Motherboard Replacement, MicroSD Card Reader: étape 5, image 2 de 2
    J'achète
    • There is a yellow tape holding the microSD card reader connector. Use tweezers to hold down the tape.
    • Gently lift the tab on the microSD card reader's ZIF connector, and gently pull the ribbon cable free.
  6. Lenovo Tab 4 TB-8504F Motherboard Replacement: étape 6, image 1 de 2 Lenovo Tab 4 TB-8504F Motherboard Replacement: étape 6, image 2 de 2
    • Lift the microSD card reader with tweezers or your fingers.
  7. Lenovo Tab 4 TB-8504F Motherboard Replacement, Rear Camera: étape 7, image 1 de 2 Lenovo Tab 4 TB-8504F Motherboard Replacement, Rear Camera: étape 7, image 2 de 2
    J'achète
    • Use a spudger to lift the rear camera press-fit connector up and free.
    • Use tweezers to lift the rear camera out of the frame.
  8. Lenovo Tab 4 TB-8504F Motherboard Replacement, Front Camera: étape 8, image 1 de 2 Lenovo Tab 4 TB-8504F Motherboard Replacement, Front Camera: étape 8, image 2 de 2
    J'achète
    • Using tweezers, lift the yellow tape hiding the front camera.
    • Disconnect the front camera's connector from the motherboard using tweezers.
  9. Lenovo Tab 4 TB-8504F Motherboard Replacement, Motherboard: étape 9, image 1 de 2 Lenovo Tab 4 TB-8504F Motherboard Replacement, Motherboard: étape 9, image 2 de 2
    J'achète
    • Use tweezers to pull screen digitizer cable from the motherboard.
  10. Lenovo Tab 4 TB-8504F Motherboard Replacement: étape 10, image 1 de 1
    • Desolder the two top speaker wires from the motherboard.
    • Be careful as the soldering iron is hot! Improper handling can result in severe burns.
  11. Lenovo Tab 4 TB-8504F Motherboard Replacement: étape 11, image 1 de 3 Lenovo Tab 4 TB-8504F Motherboard Replacement: étape 11, image 2 de 3 Lenovo Tab 4 TB-8504F Motherboard Replacement: étape 11, image 3 de 3
    • Desolder the black and red speaker wires from the motherboard.
  12. Lenovo Tab 4 TB-8504F Motherboard Replacement: étape 12, image 1 de 1
    • Use a Phillips #000 screwdriver to remove the two screws that secure the speaker to the motherboard.
  13. Lenovo Tab 4 TB-8504F Motherboard Replacement: étape 13, image 1 de 2 Lenovo Tab 4 TB-8504F Motherboard Replacement: étape 13, image 2 de 2
    • Lift motherboard from the tablet.
    • Using your hand, you can separate the top speaker from the motherboard.
3 autres ont terminé cette réparation.
Ivan Chavez
Membre depuis le 02/06/19
776 Réputation
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 6
30 derniers jours : 37
Total : 3,971
