Aller au contenu principal
Lenovo ThinkCentre M92p Hard Drive Replacement
Ce dont vous avez besoin
  1. Lenovo ThinkCentre M92p Hard Drive Replacement, Hard Drive: étape 1, image 1 de 3 Lenovo ThinkCentre M92p Hard Drive Replacement, Hard Drive: étape 1, image 2 de 3 Lenovo ThinkCentre M92p Hard Drive Replacement, Hard Drive: étape 1, image 3 de 3
    • Power off your ThinkCentre M92p, and unplug the power cable from the electrical outlet.
  2. Lenovo ThinkCentre M92p Hard Drive Replacement: étape 2, image 1 de 2 Lenovo ThinkCentre M92p Hard Drive Replacement: étape 2, image 2 de 2
    • Using a Phillips #1 screwdriver, remove the middle black screw located on the back of the ThinkCentre.
  3. Lenovo ThinkCentre M92p Hard Drive Replacement: étape 3, image 1 de 3 Lenovo ThinkCentre M92p Hard Drive Replacement: étape 3, image 2 de 3 Lenovo ThinkCentre M92p Hard Drive Replacement: étape 3, image 3 de 3
    • Use your thumbs and slide the metal housing towards the front, to remove the cover.
  4. Lenovo ThinkCentre M92p Hard Drive Replacement: étape 4, image 1 de 2 Lenovo ThinkCentre M92p Hard Drive Replacement: étape 4, image 2 de 2
    • Unplug the black connector from the damaged hard drive.
  5. Lenovo ThinkCentre M92p Hard Drive Replacement: étape 5, image 1 de 3 Lenovo ThinkCentre M92p Hard Drive Replacement: étape 5, image 2 de 3 Lenovo ThinkCentre M92p Hard Drive Replacement: étape 5, image 3 de 3
    • Use the Phillips #1 screwdriver to remove the two black screws holding the hard drive to the chassis.
  6. Lenovo ThinkCentre M92p Hard Drive Replacement: étape 6, image 1 de 3 Lenovo ThinkCentre M92p Hard Drive Replacement: étape 6, image 2 de 3 Lenovo ThinkCentre M92p Hard Drive Replacement: étape 6, image 3 de 3
    • Do not try to remove the hard drive right away .There is a red/black cable connected to the motherboard, right below the hard drive. Gently disconnect it from the *green* motherboard***.
  7. Lenovo ThinkCentre M92p Hard Drive Replacement: étape 7, image 1 de 3 Lenovo ThinkCentre M92p Hard Drive Replacement: étape 7, image 2 de 3 Lenovo ThinkCentre M92p Hard Drive Replacement: étape 7, image 3 de 3
    • Flip over the disconnected caddy/tray and use the Phillips #1 screwdriver to remove the four screws from the bottom. Then remove the hard drive.
3 autres ont terminé cette réparation.
Innocent bakajika
Membre depuis le 09/01/21
217 Réputation
1 tutoriel rédigé
Équipe
York University, Team 1-3, O'Regan Fall 2021 Membre de l'équipe York University, Team 1-3, O'Regan Fall 2021
YORK-O'REGAN-F21S1G3
1 membre
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 23
30 derniers jours : 124
Total : 5,304
