Introduction
This guide will show you how to replace the CMOS battery in your Lenovo ThinkPad E570 laptop. Your laptop may need a new CMOS battery if you are experiencing the following symptoms:
- The laptop has difficulty booting up
- There is a constant beeping noise from the motherboard
- The date and time have reset each time you restart the device
- Peripherals aren’t responsive or they don’t respond correctly
- Hardware drivers have disappeared
- You can’t connect to the internet
Power down your laptop and disconnect from any external power sources before beginning this guide.
Ce dont vous avez besoin
Turn the laptop over so that the bottom is facing upwards, with the battery facing away from you.
Loosen two captive 5 mm screws on the back panel of the laptop using a Phillips #0 screwdriver.
Slide the panel towards you, then gently lift up to remove.
