Aller au contenu principal
Lenovo ThinkPad E570 Fan Replacement
Ce dont vous avez besoin
  1. Lenovo ThinkPad E570 Fan Replacement, CMOS Battery: étape 1, image 1 de 3 Lenovo ThinkPad E570 Fan Replacement, CMOS Battery: étape 1, image 2 de 3 Lenovo ThinkPad E570 Fan Replacement, CMOS Battery: étape 1, image 3 de 3
    • Turn the laptop over so that the bottom is facing upwards, with the battery facing away from you.
    • Loosen two captive 5 mm screws on the back panel of the laptop using a Phillips #0 screwdriver.
    • Slide the panel towards you, then gently lift up to remove.
  2. Lenovo ThinkPad E570 Fan Replacement: étape 2, image 1 de 2 Lenovo ThinkPad E570 Fan Replacement: étape 2, image 2 de 2
    • Insert the flat end of the halberd spudger underneath the battery to free the it from the adhesive.
    • Unplug the connecting CMOS wire from the motherboard.
    • When reassembling, apply gentle pressure to the new CMOS battery with the adhesive pad facing down.
  3. Lenovo ThinkPad E570 Fan Replacement, Fan: étape 3, image 1 de 2 Lenovo ThinkPad E570 Fan Replacement, Fan: étape 3, image 2 de 2
    • Remove the single 5 mm screw using a Phillips #00 screwdriver.
    • Remove the SSD from the laptop.
  4. Lenovo ThinkPad E570 Fan Replacement: étape 4, image 1 de 1
    • Using an opening tool, carefully remove the black and white coaxial cables that are connected to the Wi-Fi card.
    • Remove the single 4 mm screw from the Wi-Fi card using a Phillips #0 screwdriver.
    • Carefully grab the card and pull outward to remove it from the laptop.
  5. Lenovo ThinkPad E570 Fan Replacement: étape 5, image 1 de 2 Lenovo ThinkPad E570 Fan Replacement: étape 5, image 2 de 2
    • Using both hands, push out the two buttons beneath the outer edges of the battery compartment.
    • Pull out the battery from the laptop.
  6. Lenovo ThinkPad E570 Fan Replacement: étape 6, image 1 de 2 Lenovo ThinkPad E570 Fan Replacement: étape 6, image 2 de 2
    • Remove the three screws in storage area. Then, remove warranty strip.
  7. Lenovo ThinkPad E570 Fan Replacement: étape 7, image 1 de 2 Lenovo ThinkPad E570 Fan Replacement: étape 7, image 2 de 2
    • Remove the three 4 keyboard screws in the middle of the casing and all the outer casing screws.
  8. Lenovo ThinkPad E570 Fan Replacement: étape 8, image 1 de 1
    • After removing the screws slide the disc drive out.
    • Use size 0 bit to remove three 3 screws on frame under disc drives and Flip over laptop to open it.
  9. Lenovo ThinkPad E570 Fan Replacement: étape 10, image 1 de 3 Lenovo ThinkPad E570 Fan Replacement: étape 10, image 2 de 3 Lenovo ThinkPad E570 Fan Replacement: étape 10, image 3 de 3
    • Gently press against the keyboard to slide it up and out. Then gently flip the keyboard over.
  10. Lenovo ThinkPad E570 Fan Replacement: étape 11, image 1 de 3 Lenovo ThinkPad E570 Fan Replacement: étape 11, image 2 de 3 Lenovo ThinkPad E570 Fan Replacement: étape 11, image 3 de 3
    • Disconnect the keyboard cables.
  11. Lenovo ThinkPad E570 Fan Replacement: étape 12, image 1 de 1
    • Disconnect fingerprint sensor.
  12. Lenovo ThinkPad E570 Fan Replacement: étape 13, image 1 de 1
    • Disconnect mouse cable.
  13. Lenovo ThinkPad E570 Fan Replacement: étape 14, image 1 de 1
    • Disconnect speaker cable.
  14. Lenovo ThinkPad E570 Fan Replacement: étape 15, image 1 de 1
    • Disconnect power button cable.
  15. Lenovo ThinkPad E570 Fan Replacement: étape 16, image 1 de 2 Lenovo ThinkPad E570 Fan Replacement: étape 16, image 2 de 2
    • Remove front casing screws.
  16. Lenovo ThinkPad E570 Fan Replacement: étape 17, image 1 de 2 Lenovo ThinkPad E570 Fan Replacement: étape 17, image 2 de 2
    • Wedge the casing apart.
  17. Lenovo ThinkPad E570 Fan Replacement: étape 18, image 1 de 1
    • Remove the motherboard screws.
  18. Lenovo ThinkPad E570 Fan Replacement: étape 19, image 1 de 1
    • Remove the screen cable by pulling the tab back.
  19. Lenovo ThinkPad E570 Fan Replacement: étape 20, image 1 de 1
    • The mother boards should be able to be removed at this point and flipped over to get access to the CPU chip and the fan.
  20. Lenovo ThinkPad E570 Fan Replacement: étape 21, image 1 de 2 Lenovo ThinkPad E570 Fan Replacement: étape 21, image 2 de 2
    • Disconnect Fan connector and remove the screws from the heatsink and replace the fan. (Fan part number)
KyleH
Membre depuis le 07/13/23
427 Réputation
2 tutoriels rédigés
Équipe
IUPUI, Team 1-2, Harley Summer 2023 Membre de l'équipe IUPUI, Team 1-2, Harley Summer 2023
IUPUI-HARLEY-SU23S1G2
3 membres
3 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 7
30 derniers jours : 31
Total : 306
