Introduction
This guide will help to replace the CD disk drive from the Lenovo Thinkpad Edge E520 CD Disk Drive.
Ce dont vous avez besoin
Flip over the laptop and position it with the battery being furthest away from you.
Remove the four screws on the edges of the T-Shaped plate with a Phillips #0 screwdriver.
Remove the T-Shaped plate from the back of the computer. It should come off easily if all four aforementioned screws are removed.
Unscrew the two 3.175 mm diameter and 6.35 mm length screws with keyboard symbols pointing at them using a Phillips head screwdriver.
Remove all remaining screws on the back of the device.
Screw length 6.35 mm, head 3.175 mm Screws behind battery length 3.175 mm, head 3.175 mm
The silver block contains two screws.
Unscrew the two screws to remove the clamp that holds the disk drive in place.
