Aller au contenu principal
Lenovo ThinkPad Edge E520 RAM Replacement
Ce dont vous avez besoin
  1. Lenovo ThinkPad Edge E520 RAM Replacement, Battery: étape 1, image 1 de 1
    • Power off and unplug the computer before the start of these steps.
    • Close the laptop lid.
  2. Lenovo ThinkPad Edge E520 RAM Replacement: étape 2, image 1 de 2 Lenovo ThinkPad Edge E520 RAM Replacement: étape 2, image 2 de 2
    • Flip the computer so that the back is facing upwards.
    • Locate the switch used to release the battery.
    • The switch should be located towards the hinge of the laptop near the battery pack and have a lock icon associated with it.
  3. Lenovo ThinkPad Edge E520 RAM Replacement: étape 3, image 1 de 2 Lenovo ThinkPad Edge E520 RAM Replacement: étape 3, image 2 de 2
    • Slide the switch towards the unlocked lock icon.
    • While holding it in the unlocked position, slide the battery towards the hinge.
    • Fully separate the battery pack from the back of the laptop.
  4. Lenovo ThinkPad Edge E520 RAM Replacement, Back Plate: étape 4, image 1 de 2 Lenovo ThinkPad Edge E520 RAM Replacement, Back Plate: étape 4, image 2 de 2
    • Flip over the laptop and position it with the battery being furthest away from you.
    • Remove the four screws on the edges of the T-Shaped plate with a Phillips #0 screwdriver.
    • Remove the T-Shaped plate from the back of the computer. It should come off easily if all four aforementioned screws are removed.
    • Screw length 6.35 mm, head 3.175 mm
  5. Lenovo ThinkPad Edge E520 RAM Replacement, RAM: étape 5, image 1 de 1
    • The blue tinted rectangular chips will be located opposite of the hinge.
    • They are stacked on top of one another and the second chip will be found underneath the top one.
  6. Lenovo ThinkPad Edge E520 RAM Replacement: étape 6, image 1 de 2 Lenovo ThinkPad Edge E520 RAM Replacement: étape 6, image 2 de 2
    • Locate the two thin metal tracks that hold each RAM in place.
    • Using light pressure, press the tracks outward and the RAM should pop up.
  7. Lenovo ThinkPad Edge E520 RAM Replacement: étape 7, image 1 de 1
    • A light pull on the RAM should remove it with no issues.
    • Repeat from the second step to the third step to remove the second chip.
    • On reassembly, the RAM may provide some difficulty to put it back in. Be patient and slide the ram back in the metal track and apply pressure to make sure that it is in.
    • Be sure that it is in the track so the pins do not bend. A "click" sound may be heard to indicate when it is fully seated.
2 autres ont terminé cette réparation.
Andrew Martin
Membre depuis le 03/01/18
244 Réputation
2 tutoriels rédigés
Équipe
UMass Dartmouth, Team S1-G2, Simcock Spring 2018 Membre de l'équipe UMass Dartmouth, Team S1-G2, Simcock Spring 2018
UMASSD-SIMCOCK-S18S1G2
4 membres
12 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 5
30 derniers jours : 10
Total : 1,128
