Aller au contenu principal
Lenovo ThinkPad Edge E530, E530c Processor / CPU Replacement
Ce dont vous avez besoin
Vidéo d'introduction
  1. Lenovo ThinkPad Edge E530, E530c Processor / CPU Replacement, HDD Cover: étape 1, image 1 de 3 Lenovo ThinkPad Edge E530, E530c Processor / CPU Replacement, HDD Cover: étape 1, image 2 de 3 Lenovo ThinkPad Edge E530, E530c Processor / CPU Replacement, HDD Cover: étape 1, image 3 de 3
    • Switch-off the Laptop and remove the battery.
    • The HDD/Memory Cover is held by 3x Phillips screws. Remove them.
    • Remove the Cover.
  2. Lenovo ThinkPad Edge E530, E530c Processor / CPU Replacement, Fan / Cooling System: étape 2, image 1 de 3 Lenovo ThinkPad Edge E530, E530c Processor / CPU Replacement, Fan / Cooling System: étape 2, image 2 de 3 Lenovo ThinkPad Edge E530, E530c Processor / CPU Replacement, Fan / Cooling System: étape 2, image 3 de 3
    • Disconnect the Fan cable.
    • Remove the 2x screws from the Fan module.
    • Unscrew 4x screws around the processor.
    • Carefully lift the Cooling System.
  3. Lenovo ThinkPad Edge E530, E530c Processor / CPU Replacement: étape 3, image 1 de 3 Lenovo ThinkPad Edge E530, E530c Processor / CPU Replacement: étape 3, image 2 de 3 Lenovo ThinkPad Edge E530, E530c Processor / CPU Replacement: étape 3, image 3 de 3
    • Use a lint-free cloth and isopropyl alcohol to clean the old thermal compound.
    • If the thermal compound is solidified, you can use a flat end of any plastic tool to scrape it off.
    • Separate the Fan from the Heat-sink.
  4. Lenovo ThinkPad Edge E530, E530c Processor / CPU Replacement: étape 4, image 1 de 1
    • Use a soft anti static brush and clean the Heat-sink on the inside.
    • Before installing a new Cooling System or reinstalling the old one, you must clean the processor from the old thermal compound and put a new one.
  5. Lenovo ThinkPad Edge E530, E530c Processor / CPU Replacement, Processor / CPU: étape 5, image 1 de 3 Lenovo ThinkPad Edge E530, E530c Processor / CPU Replacement, Processor / CPU: étape 5, image 2 de 3 Lenovo ThinkPad Edge E530, E530c Processor / CPU Replacement, Processor / CPU: étape 5, image 3 de 3
    • Clean the old thermal compound. Use a lint-free cloth and isopropyl alcohol to clean the old thermal compound.
    • To remove the Processor, turn the CPU socket screw 90 degrees to open the socket.
    • Lift the Processor from the socket.
    • Be careful to lift straight up without bending the CPU pins.
  6. Lenovo ThinkPad Edge E530, E530c Processor / CPU Replacement: étape 6, image 1 de 2 Lenovo ThinkPad Edge E530, E530c Processor / CPU Replacement: étape 6, image 2 de 2
    • Before you place the new Processor, be sure the socket screw is in the open position.
    • Delicately place the Processor into the socket.
    • Close the socket with the socket screw.
    • Put thermal compound on the processor surface and carefully install back the Cooling system.
3 autres ont terminé cette réparation.
ZFix
Membre depuis le 12/09/13
191 368 Réputation
330 tutoriels rédigés
Équipe
Master Techs Membre de l'équipe Master Techs
Community
321 membres
1 463 tutoriels rédigés
2 commentaires
Bonjour, peut-on remplacer le CPU par n'importe quel autre plus puissant, ou y a-t-il des restrictions ?
francoislaurent - Réponse
This guide works for E531 as well
adrium - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 12
30 derniers jours : 32
Total : 7,141
