Aller au contenu principal
Lenovo ThinkPad Edge E530 Fan / Cooling System Replacement / Cleaning
Ce dont vous avez besoin
Vidéo d'introduction
  1. Lenovo ThinkPad Edge E530 Fan / Cooling System Replacement / Cleaning, HDD Cover: étape 1, image 1 de 3 Lenovo ThinkPad Edge E530 Fan / Cooling System Replacement / Cleaning, HDD Cover: étape 1, image 2 de 3 Lenovo ThinkPad Edge E530 Fan / Cooling System Replacement / Cleaning, HDD Cover: étape 1, image 3 de 3
    • Switch-off the Laptop and remove the battery.
    • The HDD/Memory Cover is held by 3x Phillips screws. Remove them.
    • Remove the Cover.
  2. Lenovo ThinkPad Edge E530 Fan / Cooling System Replacement / Cleaning, Fan / Cooling System: étape 2, image 1 de 3 Lenovo ThinkPad Edge E530 Fan / Cooling System Replacement / Cleaning, Fan / Cooling System: étape 2, image 2 de 3 Lenovo ThinkPad Edge E530 Fan / Cooling System Replacement / Cleaning, Fan / Cooling System: étape 2, image 3 de 3
    • Disconnect the Fan cable.
    • Remove the 2x screws from the Fan module.
    • Unscrew 4x screws around the processor.
    • Carefully lift the Cooling System.
  3. Lenovo ThinkPad Edge E530 Fan / Cooling System Replacement / Cleaning: étape 3, image 1 de 3 Lenovo ThinkPad Edge E530 Fan / Cooling System Replacement / Cleaning: étape 3, image 2 de 3 Lenovo ThinkPad Edge E530 Fan / Cooling System Replacement / Cleaning: étape 3, image 3 de 3
    • Use a lint-free cloth and isopropyl alcohol to clean the old thermal compound.
    • If the thermal compound is solidified, you can use a flat end of any plastic tool to scrape it off.
    • Separate the Fan from the Heat-sink.
  4. Lenovo ThinkPad Edge E530 Fan / Cooling System Replacement / Cleaning: étape 4, image 1 de 1
    • Use a soft anti static brush and clean the Heat-sink on the inside.
    • Before installing a new Cooling System or reinstalling the old one, you must clean the processor from the old thermal compound and put a new one.
3 autres ont terminé cette réparation.
ZFix
Membre depuis le 12/09/13
191 368 Réputation
330 tutoriels rédigés
Équipe
Master Techs Membre de l'équipe Master Techs
Community
321 membres
1 464 tutoriels rédigés
3 commentaires
Very, very well done video on this guide for the Lenovo Thinkpad e530 laptop.
My compliments to the author of this guide.
James Harnsberger - Réponse
will i need thermal paste to do this?
dErpyto3z Eeee - Réponse
thanks its clear
Kayan Dev - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 10
30 derniers jours : 23
Total : 8,028
