Aller au contenu principal
Lenovo ThinkPad Edge E530 HDD Replacement
Ce dont vous avez besoin
Vidéo d'introduction
  1. Lenovo ThinkPad Edge E530 HDD Replacement, HDD Cover: étape 1, image 1 de 3 Lenovo ThinkPad Edge E530 HDD Replacement, HDD Cover: étape 1, image 2 de 3 Lenovo ThinkPad Edge E530 HDD Replacement, HDD Cover: étape 1, image 3 de 3
    • Switch-off the Laptop and remove the battery.
    • The HDD/Memory Cover is held by 3x Phillips screws. Remove them.
    • Remove the Cover.
  2. Lenovo ThinkPad Edge E530 HDD Replacement, HDD (Hard Disk Drive): étape 2, image 1 de 3 Lenovo ThinkPad Edge E530 HDD Replacement, HDD (Hard Disk Drive): étape 2, image 2 de 3 Lenovo ThinkPad Edge E530 HDD Replacement, HDD (Hard Disk Drive): étape 2, image 3 de 3
    • There are 2 x philips screws, securing the HDD Caddy Case. Remove them and slide the HDD to disconnect it from the SATA Connector.
    • The Caddy Case is held to the HDD by 4x Phillips screws. Remove them and separate the HDD from the case.
    • After installing the new HDD you must install a new OS or clone your old HDD.
    • You can install SATA HDD, 2.5" up to 1TB.
    • Did you do it successfully?
7 autres ont terminé cette réparation.
ZFix
Membre depuis le 12/09/13
191 278 Réputation
330 tutoriels rédigés
Équipe
Master Techs Membre de l'équipe Master Techs
Community
322 membres
2 532 tutoriels rédigés
2 commentaires
Since you mention cloning, it would be good to know how to clone one’s old drive. Would this also clone any errors on the oldrive and then put them on the new drive???
David Abineri - Réponse
Thanks for the guide. It also works for the ThinkPad Edge E531 model.
Célestin Taramarcaz - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 17
Total : 10,188
