Aller au contenu principal
Lenovo ThinkPad L440 Motherboard Replacement
Ce dont vous avez besoin
  1. Lenovo ThinkPad L440 Motherboard Replacement, Battery: étape 1, image 1 de 3 Lenovo ThinkPad L440 Motherboard Replacement, Battery: étape 1, image 2 de 3 Lenovo ThinkPad L440 Motherboard Replacement, Battery: étape 1, image 3 de 3
    • Open the laptop to access the power button.
    • Hold the power button in the top right until the computer powers off.
    • Turn the computer over so that the bottom of the computer is facing up
  2. Lenovo ThinkPad L440 Motherboard Replacement: étape 2, image 1 de 1
    • On the left side under the raised surface, move the tab to the left towards the unlocked symbol. Repeat this on the right side and move the tab to the right towards the unlocked symbol.
  3. Lenovo ThinkPad L440 Motherboard Replacement: étape 3, image 1 de 2 Lenovo ThinkPad L440 Motherboard Replacement: étape 3, image 2 de 2
    • From the top of the laptop, slide the raised surface away from the rest of the laptop and out of its slot to remove the battery from the computer.
  4. Lenovo ThinkPad L440 Motherboard Replacement, Keyboard‎: étape 4, image 1 de 3 Lenovo ThinkPad L440 Motherboard Replacement, Keyboard‎: étape 4, image 2 de 3 Lenovo ThinkPad L440 Motherboard Replacement, Keyboard‎: étape 4, image 3 de 3
    • Insert the pointed end of a spudger into the notch on the left side first, and apply gentle pressure upwards until the frame around the keyboard moves up. Repeat for the other side.
    • The spudger used in this guide is NOT ESD-safe, so be cautious when working on your device.
  5. Lenovo ThinkPad L440 Motherboard Replacement: étape 5, image 1 de 1
    • Loosen the six captive screws using a Phillips #00 screwdriver.
  6. Lenovo ThinkPad L440 Motherboard Replacement: étape 6, image 1 de 3 Lenovo ThinkPad L440 Motherboard Replacement: étape 6, image 2 de 3 Lenovo ThinkPad L440 Motherboard Replacement: étape 6, image 3 de 3
    • Lift the edge of the keyboard using the blunt side of the spudger, and bring it straight up and out towards you. Lay the keyboard flat on top of the trackpad.
    • Be careful as the keyboard still has ribbon connectors connected to the laptop.
    • To reassemble, gently push down on all sides of the keyboard.
  7. Lenovo ThinkPad L440 Motherboard Replacement: étape 7, image 1 de 3 Lenovo ThinkPad L440 Motherboard Replacement: étape 7, image 2 de 3 Lenovo ThinkPad L440 Motherboard Replacement: étape 7, image 3 de 3
    • Pull the black latch over the connectors up towards the screen with your nail.
    • Grab onto the blue part and, with gentle pressure, pull straight back towards you to release the ribbon cable.
    • Repeat for the second, smaller ribbon connector.
    • These parts are fragile, and can tear easily, so take your time, go gently, and make sure to pull straight towards you.
  8. Lenovo ThinkPad L440 Motherboard Replacement, Back Panel: étape 8, image 1 de 2 Lenovo ThinkPad L440 Motherboard Replacement, Back Panel: étape 8, image 2 de 2
    • Loosen the four retainer screws on the bottom of the laptop using a Phillips #0 screwdriver.
    • These four screws are attached to the panel with washers, so they will spin freely when they are loose and will come off with the panel.
  9. Lenovo ThinkPad L440 Motherboard Replacement: étape 9, image 1 de 2 Lenovo ThinkPad L440 Motherboard Replacement: étape 9, image 2 de 2
    • With your fingers, lift up the back panel from the left side.
  10. Lenovo ThinkPad L440 Motherboard Replacement, CD Drive: étape 10, image 1 de 1
    • Remove the 6 mm CD drive set screw using a Phillips #00 screwdriver.
  11. Lenovo ThinkPad L440 Motherboard Replacement: étape 11, image 1 de 3 Lenovo ThinkPad L440 Motherboard Replacement: étape 11, image 2 de 3 Lenovo ThinkPad L440 Motherboard Replacement: étape 11, image 3 de 3
    • Rotate the laptop so that the CD drive is facing you.
    • Grasp the CD drive with your fingers and pull straight outwards.
  12. Lenovo ThinkPad L440 Motherboard Replacement, RAM: étape 12, image 1 de 2 Lenovo ThinkPad L440 Motherboard Replacement, RAM: étape 12, image 2 de 2
    • Pull the tabs on either side of the RAM in opposite directions.
    • Pull the RAM stick up and out.
    • Repeat for the second RAM stick.
  13. Lenovo ThinkPad L440 Motherboard Replacement, Hard Drive: étape 13, image 1 de 2 Lenovo ThinkPad L440 Motherboard Replacement, Hard Drive: étape 13, image 2 de 2
    • Remove the single 3.5 mm screw next to the hard drive using a Phillips #00 screwdriver.
    • Remove the hard drive from the laptop.
  14. Lenovo ThinkPad L440 Motherboard Replacement, Motherboard: étape 14, image 1 de 3 Lenovo ThinkPad L440 Motherboard Replacement, Motherboard: étape 14, image 2 de 3 Lenovo ThinkPad L440 Motherboard Replacement, Motherboard: étape 14, image 3 de 3
    • Use a pair of tweezers to detach the black and grey internet cables from the back of the computer and remove them from the coaxial connectors.
    • Remove the yellow CMOS battery from the computer.
  15. Lenovo ThinkPad L440 Motherboard Replacement: étape 15, image 1 de 1
    • Remove six 3.5 mm silver screws using a Phillips #00 screwdriver.
    • Remove the three 6 mm black screws using a Phillips #00 screwdriver.
    • Remove the two 12 mm black screws using a Phillips #00 screwdriver.
  16. Lenovo ThinkPad L440 Motherboard Replacement: étape 16, image 1 de 3 Lenovo ThinkPad L440 Motherboard Replacement: étape 16, image 2 de 3 Lenovo ThinkPad L440 Motherboard Replacement: étape 16, image 3 de 3
    • Fully loosen the four captive screws in the bottom left part of the heat sink.
    • Remove the sliding cable from the side of the heatsink.
    • Pull the heat sink out of the computer.
  17. Lenovo ThinkPad L440 Motherboard Replacement: étape 17, image 1 de 2 Lenovo ThinkPad L440 Motherboard Replacement: étape 17, image 2 de 2
    • Flip the computer over to the front.
    • Remove the black display cable from the motherboard.
    • Remove the single 6 mm black screw in the center of the keyboard.
  18. Lenovo ThinkPad L440 Motherboard Replacement: étape 18, image 1 de 2 Lenovo ThinkPad L440 Motherboard Replacement: étape 18, image 2 de 2
    • Pull up the tab on each keyboard ribbon cable to disconnect them from the motherboard.
    • Lift the computer up and bring the internet cables from the back to the top of the computer.
    • Keep pulling on the wires following the path of the wires until they are loose from the cover for the motherboard.
  19. Lenovo ThinkPad L440 Motherboard Replacement: étape 19, image 1 de 3 Lenovo ThinkPad L440 Motherboard Replacement: étape 19, image 2 de 3 Lenovo ThinkPad L440 Motherboard Replacement: étape 19, image 3 de 3
    • Insert a metal spudger into the gap between the casing and the rest of the laptop.
    • Slide the spudger around the edges of the computer.
    • Pull the casing out and away from the computer.
  20. Lenovo ThinkPad L440 Motherboard Replacement: étape 20, image 1 de 2 Lenovo ThinkPad L440 Motherboard Replacement: étape 20, image 2 de 2
    • Remove the four 6 mm black screws from the motherboard using a Phillips #00 screwdriver.
  21. Lenovo ThinkPad L440 Motherboard Replacement: étape 21, image 1 de 3 Lenovo ThinkPad L440 Motherboard Replacement: étape 21, image 2 de 3 Lenovo ThinkPad L440 Motherboard Replacement: étape 21, image 3 de 3
    • Remove the sliding speaker cable in the bottom left of the computer.
    • Lift the motherboard away from the computer by pulling left and outwards.
    • Remove the sliding power cable on the back of the motherboard.
Bobby Kennedy
Membre depuis le 10/18/24
353 Réputation
2 tutoriels rédigés
Équipe
UMass Dartmouth, Team 2-6, Konn Fall 2024 Membre de l'équipe UMass Dartmouth, Team 2-6, Konn Fall 2024
UMASSD-KONN-F24S2G6
4 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 13
30 derniers jours : 40
Total : 160
