Introduction
This guide shows how to replace the hard drive in a Lenovo ThinkPad L460.
The hard drive stores the operating system, applications, and personal files. If your laptop runs slowly, freezes frequently, makes unusual noises, or doesn’t have enough storage, replacing the drive may improve performance.
Upgrading to a new HDD or SSD can reduce boot times, improve everyday responsiveness, and add storage—helping extend the life of the ThinkPad L460.
Before you begin, back up your data, power off the laptop, and unplug it from any power source.
Ce dont vous avez besoin
Shut down your Lenovo ThinkPad L460 completely.
Disconnect the AC power adapter.
Disconnect all connected cables and devices.
Use a Phillips #1 screwdriver to loosen the 8 captive screws on the back cover of the laptop.
Remove the SIM tray from the side of the laptop.
Note: If the model had internal battery disconnect it from the motherboard.
Locate the Hard drive. There will be a 2.5″ drive in a bay, likely secured by a screws and held in a caddy or mount.
Remove the screws and any caddy or mounting.
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
