Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Lenovo ThinkPad L460 RAM Replacement
Ce dont vous avez besoin
  1. Lenovo ThinkPad L460 RAM Replacement, Battery: étape 1, image 1 de 1
    • Shut down your Lenovo ThinkPad L460 completely.
    • Disconnect the AC power adapter.
    • Disconnect all connected cables and devices.
    Demander à FixBot
    Ajouter un commentaire
  2. Lenovo ThinkPad L460 RAM Replacement: étape 2, image 1 de 1
    • Flip the laptop so the bottom is facing upwards.
    Demander à FixBot
  3. Lenovo ThinkPad L460 RAM Replacement: étape 3, image 1 de 2 Lenovo ThinkPad L460 RAM Replacement: étape 3, image 2 de 2
    • Use your two thumbs to push the two locking latches to the left and the right of the battery to the unlocked position.
    • While holding the latches open, slide the battery out of the connector to remove it.
    Demander à FixBot
  4. Lenovo ThinkPad L460 RAM Replacement, Back Cover: étape 4, image 1 de 1
    • Use a Phillips #1 screwdriver to loosen the 8 captive screws on the back cover of the laptop.
    • Captive screws are not meant to be removed, just loosened enough.
    • Remove the SIM tray from the side of the laptop.
    Demander à FixBot
  5. Lenovo ThinkPad L460 RAM Replacement: étape 5, image 1 de 2 Lenovo ThinkPad L460 RAM Replacement: étape 5, image 2 de 2
    • Use an opening tool to gently pry along the edges of the cover, releasing all the plastic clips of the laptop.
    • Carefully pull up and remove the back cover from the laptop.
    Demander à FixBot
  6. Lenovo ThinkPad L460 RAM Replacement, RAM: étape 6, image 1 de 1
    • Use your hands to flip the black flap covering the RAM module.
    Demander à FixBot
  7. Lenovo ThinkPad L460 RAM Replacement: étape 7, image 1 de 1
    • Use your hands to push out the metal clips on both sides of the RAM.
    • The RAM module will pop up at about a 30 degree angle when it's released from the metal arms.
    Demander à FixBot
  8. Lenovo ThinkPad L460 RAM Replacement: étape 8, image 1 de 1
    • Use your fingers to gently slide the RAM module out of its socket.
    Demander à FixBot
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Samuel Paintsil
Membre depuis le 10/17/25
531 Réputation
2 tutoriels rédigés
Équipe
UMass Dartmouth, Team 2-4, Bowman Fall 2025 Membre de l'équipe UMass Dartmouth, Team 2-4, Bowman Fall 2025
UMASSD-BOWMAN-F25S2G4
4 membres
6 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 8
30 derniers jours : 28
Total : 245
