Aller au contenu principal
Lenovo ThinkPad R61i Hard Drive Replacement
Ce dont vous avez besoin
  1. Lenovo ThinkPad R61i Hard Drive Replacement, Gather Materials: étape 1, image 1 de 1
    • You will need to have a replacement drive ready. The R61i officially supports SATA I speeds, but if you flash the Middleton's BIOS, you will get the full SATA II speed. If you plan on upgrading to an SSD during this process, I would recommend flashing Middleton's BIOS. Get more information & download links here
  2. Lenovo ThinkPad R61i Hard Drive Replacement, Remove the battery & unplug power adapter: étape 2, image 1 de 2 Lenovo ThinkPad R61i Hard Drive Replacement, Remove the battery & unplug power adapter: étape 2, image 2 de 2
    • You may need to apply a good amount of force to the levers that hold the battery in place. Mine was especially well stuck, as it was a recently installed aftermarket battery.
  3. Lenovo ThinkPad R61i Hard Drive Replacement, Remove the HDD caddy's cover: étape 3, image 1 de 1
    • Locate and remove the #2 philips screw on the hard drive bay cover.
    • Pull the hard drive bay cover straight out. Mine required a good bit of wiggling and force before it came out of the computer.
  4. Lenovo ThinkPad R61i Hard Drive Replacement, Remove the caddy & hard drive: étape 4, image 1 de 3 Lenovo ThinkPad R61i Hard Drive Replacement, Remove the caddy & hard drive: étape 4, image 2 de 3 Lenovo ThinkPad R61i Hard Drive Replacement, Remove the caddy & hard drive: étape 4, image 3 de 3
    • Locate the plastic tab that you will need to use to remove the caddy. I recommend using the iFixit plastic tool to remove this, as most screwdrivers could tear or scratch the plastic or drive caddy.
    • Pull the hard drive and caddy straight out of the machine.
  5. Lenovo ThinkPad R61i Hard Drive Replacement, Remove the rubber sleds from the drive caddy: étape 5, image 1 de 2 Lenovo ThinkPad R61i Hard Drive Replacement, Remove the rubber sleds from the drive caddy: étape 5, image 2 de 2
    • Remove the two rubber sleds from the drive caddy.
  6. Lenovo ThinkPad R61i Hard Drive Replacement, Remove the hard drive from the caddy: étape 6, image 1 de 1
    • Remove the four phillips head screws around the hard drive. Do not lose these, as they will be used to install your new hard drive or SSD!
Congratulations! To re-assemble the device, follow the guide in reverse order.
Sam
Membre depuis le 02/24/17
648 Réputation
3 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 14
30 derniers jours : 31
Total : 1,898
