Aller au contenu principal
Lenovo ThinkPad T400 Hard Drive Replacement
Ce dont vous avez besoin
  1. Lenovo ThinkPad T400 Hard Drive Replacement, Hard drive: étape 1, image 1 de 1
    • Safe Shutdown: Press the "Windows" button and select "Shut down" or simply turn off the power, by pressing the power button for about 3-5 seconds until the screen completely turns off.
    • If your system is working now, please make sure to save all of files while in progress.
    • With a force shutdown, the work that hasn't been saved can be lost.
  2. Lenovo ThinkPad T400 Hard Drive Replacement: étape 2, image 1 de 2 Lenovo ThinkPad T400 Hard Drive Replacement: étape 2, image 2 de 2
    • Remove the power cord.
    • Using the switch on the battery, slide and pull to remove it.
  3. Lenovo ThinkPad T400 Hard Drive Replacement: étape 3, image 1 de 2 Lenovo ThinkPad T400 Hard Drive Replacement: étape 3, image 2 de 2
    • Using a flathead screwdriver, remove the two screws that are holding the hard drive cover in place on the back corner of the computer.
  4. Lenovo ThinkPad T400 Hard Drive Replacement: étape 4, image 1 de 1
    • Use a flathead screwdriver to gently pry up the cover and remove it completely.
  5. Lenovo ThinkPad T400 Hard Drive Replacement: étape 5, image 1 de 1
    • Use the pull tab on the hard drive to completely pull out the hard drive. Please pull out slowly and gently.
  6. Lenovo ThinkPad T400 Hard Drive Replacement: étape 6, image 1 de 1
    • Using a #00 Phillips head screwdriver, remove all four screws on the hard drive cover.
  7. Lenovo ThinkPad T400 Hard Drive Replacement: étape 7, image 1 de 1
    • Remove the side bumpers from the original hard drive and place them on the new hard drive.
  8. Lenovo ThinkPad T400 Hard Drive Replacement: étape 8, image 1 de 1
    • Snap cover onto the new hard driver and tighten the four screws with a #00 Phillips head screwdriver. Then insert it back into the computer.
    • Make sure the black tab is facing out, like when it was removed.
  9. Lenovo ThinkPad T400 Hard Drive Replacement: étape 9, image 1 de 1
    • Put cover back on computer and tighten screws with a flathead screw driver.
At the end of this fix, you can plug in your computer/ attach battery and turn on the computer.
5 autres ont terminé cette réparation.
Tanner Therrien
Membre depuis le 06/20/18
289 Réputation
1 tutoriel rédigé
Équipe
Washington State, Team S1-G3, Hope Summer 2018 Membre de l'équipe Washington State, Team S1-G3, Hope Summer 2018
WSU-HOPE-SU18S1G3
3 membres
1 tutoriel rédigé
2 commentaires
OK thru Step 5. Then, the Phillips screws are neither visible nor accessible until after the side bumpers have been removed. Likewise, the side bumper replacement must be the last thing done before the drive re-insertion. A small nit-pik for an otherwise clear and helpful procedure. Thanks!
cyanth - Réponse
thank you for this, much easier than expected even for me…
mridgway89 - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 11
30 derniers jours : 61
Total : 10,259
