Aller au contenu principal
Lenovo ThinkPad T400s CMOS Battery Replacement
Ce dont vous avez besoin
  1. Lenovo ThinkPad T400s CMOS Battery Replacement, Keyboard: étape 1, image 1 de 2 Lenovo ThinkPad T400s CMOS Battery Replacement, Keyboard: étape 1, image 2 de 2
    • Remove the Phillips #0-6mm screw.
    • Lift up the back cover to the RAM cards.
  2. Lenovo ThinkPad T400s CMOS Battery Replacement: étape 2, image 1 de 2 Lenovo ThinkPad T400s CMOS Battery Replacement: étape 2, image 2 de 2
    • Pull the lock for the baterry to the left to unlock.
    • While holding the tab in the unlocked position, remove the battery.
  3. Lenovo ThinkPad T400s CMOS Battery Replacement: étape 3, image 1 de 1
    • Remove the three Phillips #0-6mm screws on the back panel.
    • These screws are marked with a keyboard symbol next to them.
  4. Lenovo ThinkPad T400s CMOS Battery Replacement: étape 4, image 1 de 3 Lenovo ThinkPad T400s CMOS Battery Replacement: étape 4, image 2 de 3 Lenovo ThinkPad T400s CMOS Battery Replacement: étape 4, image 3 de 3
    • Turn the computer over and open the lid.
    • Wedge the small metal spudger between the palm rest and the keyboard.
  5. Lenovo ThinkPad T400s CMOS Battery Replacement: étape 5, image 1 de 3 Lenovo ThinkPad T400s CMOS Battery Replacement: étape 5, image 2 de 3 Lenovo ThinkPad T400s CMOS Battery Replacement: étape 5, image 3 de 3
    • Lift up the keyboard, but be careful not to completely remove.
    • Don't lift the keyboard too quickly, there is a connector cable you must disconnect first.
    • Wedge the small plastic opening tool underneath copper band and tilt back.
    • Remove keyboard to replace.
  6. Lenovo ThinkPad T400s CMOS Battery Replacement, CMOS Battery: étape 6, image 1 de 1
    • Gently pull the back-up battery from underneath the front panel.
  7. Lenovo ThinkPad T400s CMOS Battery Replacement: étape 7, image 1 de 2 Lenovo ThinkPad T400s CMOS Battery Replacement: étape 7, image 2 de 2
    • Pull on the black connection piece and remove the back-up battery.
4 autres ont terminé cette réparation.
Morgan Montalvo
Membre depuis le 04/14/15
652 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team 6-18, Maness Spring 2015 Membre de l'équipe Cal Poly, Team 6-18, Maness Spring 2015
CPSU-MANESS-S15S6G18
4 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 6
7 derniers jours : 16
30 derniers jours : 72
Total : 21,583
