Aller au contenu principal
Lenovo ThinkPad T410s Keyboard Replacement
Ce dont vous avez besoin
  1. Lenovo ThinkPad T410s Keyboard Replacement, Battery: étape 1, image 1 de 1
    • Flip the laptop over.
    • Push and hold the locking switch to the left.
    • Pull the battery out with your other hand.
  2. Lenovo ThinkPad T410s Keyboard Replacement, RAM: étape 2, image 1 de 2 Lenovo ThinkPad T410s Keyboard Replacement, RAM: étape 2, image 2 de 2
    • Remove the single Phillips #0 screw grin the back panel.
    • Pull the back panel off.
  3. Lenovo ThinkPad T410s Keyboard Replacement: étape 3, image 1 de 3 Lenovo ThinkPad T410s Keyboard Replacement: étape 3, image 2 de 3 Lenovo ThinkPad T410s Keyboard Replacement: étape 3, image 3 de 3
    • Pull the metal prongs at the side of the RAM away from each other.
    • The RAM will pop out of its socket when done correctly.
    • Pull the RAM out.
  4. Lenovo ThinkPad T410s Keyboard Replacement, Hard Drive: étape 4, image 1 de 2 Lenovo ThinkPad T410s Keyboard Replacement, Hard Drive: étape 4, image 2 de 2
    • Remove the single Phillips #0 screw that secures the hard drive cover.
  5. Lenovo ThinkPad T410s Keyboard Replacement: étape 5, image 1 de 2 Lenovo ThinkPad T410s Keyboard Replacement: étape 5, image 2 de 2
    • Flip the black plastic tab out.
  6. Lenovo ThinkPad T410s Keyboard Replacement: étape 6, image 1 de 2 Lenovo ThinkPad T410s Keyboard Replacement: étape 6, image 2 de 2
    • Pull the hard drive out.
  7. Lenovo ThinkPad T410s Keyboard Replacement, Keyboard: étape 7, image 1 de 1
    • Remove the Flathead 2.5mm screw.
  8. Lenovo ThinkPad T410s Keyboard Replacement: étape 8, image 1 de 2 Lenovo ThinkPad T410s Keyboard Replacement: étape 8, image 2 de 2
    • Wedge the flat end of a spudger, or plastic opening tool, under the end of the keyboard and pry up.
  9. Lenovo ThinkPad T410s Keyboard Replacement: étape 9, image 1 de 2 Lenovo ThinkPad T410s Keyboard Replacement: étape 9, image 2 de 2
    • Slide the keyboard out of the way until you can see what's underneath it.
    • The keyboard is still attached with a ribbon cable so don't try to fully remove it.
  10. Lenovo ThinkPad T410s Keyboard Replacement: étape 10, image 1 de 1
    • Use the flat end of a spudger to unplug the keyboard connector from the laptop.
    • Pull the keyboard out.
Blake Wilson
Membre depuis le 02/21/18
117 Réputation
1 tutoriel rédigé
Équipe
0Commentaires sur le guide
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 8
30 derniers jours : 80
Total : 3,170
