Aller au contenu principal
Lenovo ThinkPad T430s Display Replacement
Ce dont vous avez besoin
  1. Lenovo ThinkPad T430s Display Replacement, Battery: étape 1, image 1 de 3 Lenovo ThinkPad T430s Display Replacement, Battery: étape 1, image 2 de 3 Lenovo ThinkPad T430s Display Replacement, Battery: étape 1, image 3 de 3
    • Flip your ThinkPad on its back.
    • In the bottom left corner of your ThinkPad, slide the lever to the left. Hold the lever there.
    • Use your other hand to lift the battery up by prying the notch to the left of the lever.
    • Tilt the battery up and remove it from the ThinkPad.
  2. Lenovo ThinkPad T430s Display Replacement, Display: étape 2, image 1 de 3 Lenovo ThinkPad T430s Display Replacement, Display: étape 2, image 2 de 3 Lenovo ThinkPad T430s Display Replacement, Display: étape 2, image 3 de 3
    • Rotate your ThinkPad so the back side faces you.
    • With the Phillips #1 screwdriver, remove the two 70 mm screws in the right and left corners.
    • Open the ThinkPad so the screen faces up. Lift the screen from its hinges.
  3. Lenovo ThinkPad T430s Display Replacement: étape 3, image 1 de 3 Lenovo ThinkPad T430s Display Replacement: étape 3, image 2 de 3 Lenovo ThinkPad T430s Display Replacement: étape 3, image 3 de 3
    • With the Phillips #0 screwdriver, remove the two 50 mm screws securing the plastic display case.
    • Wedge the flat end of the spudger in between the display case and the screen. Unsnap the top case from the bottom piece holding the screen.
    • Remove the case and set it aside.
  4. Lenovo ThinkPad T430s Display Replacement: étape 4, image 1 de 3 Lenovo ThinkPad T430s Display Replacement: étape 4, image 2 de 3 Lenovo ThinkPad T430s Display Replacement: étape 4, image 3 de 3
    • Unscrew the four 30 mm screws holding the screen to the case.
    • Lift the screen out of the case.
    • Flip the screen over.
  5. Lenovo ThinkPad T430s Display Replacement: étape 5, image 1 de 3 Lenovo ThinkPad T430s Display Replacement: étape 5, image 2 de 3 Lenovo ThinkPad T430s Display Replacement: étape 5, image 3 de 3
    • Peel away the tape holding the cable down with the flat end of the spudger.
    • Pull the cable out of its socket.
Melissa Rogers
Membre depuis le 09/02/20
681 Réputation
5 tutoriels rédigés
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 47
30 derniers jours : 108
Total : 2,409
