Introduction
This guide will show you how to locate and replace the Lenovo T431s battery. The battery provides proper power to the computer for its functions. Replacing your battery can be beneficial to improve computer usage and lifetime. If your laptop dies frequently or doesn’t power on, then you should consider replacing your battery.
Ce dont vous avez besoin
Use a Phillips #1 screwdriver bit to remove the eight 5mm screws from the back panel.
Once the screws are loose, use the three opening tools to loosen and remove the back panel.
3 autres ont terminé cette réparation.
