Aller au contenu principal
Lenovo ThinkPad T431S Fan Replacement
Ce dont vous avez besoin
  1. Lenovo ThinkPad T431S Fan Replacement, Fan: étape 1, image 1 de 2 Lenovo ThinkPad T431S Fan Replacement, Fan: étape 1, image 2 de 2
    • Remember before starting any disassembly, to prevent electric shock or harm, disconnect from any external power source and make sure device is powered off.
    • Use a Phillips #1 screwdriver bit to remove eight 5.0 mm screws from the back panel.
    • Carefully pry off the back panel using the opening tool.
  2. Lenovo ThinkPad T431S Fan Replacement: étape 2, image 1 de 2 Lenovo ThinkPad T431S Fan Replacement: étape 2, image 2 de 2
    • Use a Phillips #1 screwdriver bit and remove the four 3.0 mm screws from the heatsink.
  3. Lenovo ThinkPad T431S Fan Replacement: étape 3, image 1 de 3 Lenovo ThinkPad T431S Fan Replacement: étape 3, image 2 de 3 Lenovo ThinkPad T431S Fan Replacement: étape 3, image 3 de 3
    • Disconnect the cable attached to the fan, pulling the connector straight down.
    • Lift and remove the fan.
2 autres ont terminé cette réparation.
Un commentaire
Well done. I will have a go at fixing the fan on my T430s now that I’ve seen how easy it is to do.
Jocko - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 4
30 derniers jours : 11
Total : 333
