Aller au contenu principal
Lenovo ThinkPad T440p Display Replacement
Ce dont vous avez besoin
  1. Lenovo ThinkPad T440p Display Replacement, Display: étape 1, image 1 de 2 Lenovo ThinkPad T440p Display Replacement, Display: étape 1, image 2 de 2
    • Flip the laptop over so that the bottom of the laptop is facing you.
  2. Lenovo ThinkPad T440p Display Replacement: étape 2, image 1 de 2 Lenovo ThinkPad T440p Display Replacement: étape 2, image 2 de 2
    • Slide each of the battery latches away from each other into the unlocked location.
  3. Lenovo ThinkPad T440p Display Replacement: étape 3, image 1 de 2 Lenovo ThinkPad T440p Display Replacement: étape 3, image 2 de 2
    • Slide the battery out of the battery compartment.
  4. Lenovo ThinkPad T440p Display Replacement: étape 4, image 1 de 2 Lenovo ThinkPad T440p Display Replacement: étape 4, image 2 de 2
    • Flip the laptop over so that the top of the laptop faces you.
  5. Lenovo ThinkPad T440p Display Replacement: étape 5, image 1 de 2 Lenovo ThinkPad T440p Display Replacement: étape 5, image 2 de 2
    • Lift the lid of the laptop until the top of the lid is touching the ground.
  6. Lenovo ThinkPad T440p Display Replacement: étape 6, image 1 de 3 Lenovo ThinkPad T440p Display Replacement: étape 6, image 2 de 3 Lenovo ThinkPad T440p Display Replacement: étape 6, image 3 de 3
    • Carefully pry the display bezels away from the display using the plastic opening tool.
    • The edges on the underside of the bezel that touches the display may be sharp.
  7. Lenovo ThinkPad T440p Display Replacement: étape 7, image 1 de 2 Lenovo ThinkPad T440p Display Replacement: étape 7, image 2 de 2
    • Use the Phillips #0 screwdriver to remove the four 3mm display screws.
  8. Lenovo ThinkPad T440p Display Replacement: étape 8, image 1 de 1
    • Carefully lift the display up and place it on the keyboard.
    • Don't remove it from the laptop. There's a cable still attached to it.
  9. Lenovo ThinkPad T440p Display Replacement: étape 9, image 1 de 3 Lenovo ThinkPad T440p Display Replacement: étape 9, image 2 de 3 Lenovo ThinkPad T440p Display Replacement: étape 9, image 3 de 3
    • Locate the latch attached to the display cable.
    • Grab the latch and flip it over so that it is facing away from you.
  10. Lenovo ThinkPad T440p Display Replacement: étape 10, image 1 de 1
    • Gently remove the cable from the display by pulling it directly away from you.
  11. Lenovo ThinkPad T440p Display Replacement: étape 11, image 1 de 2 Lenovo ThinkPad T440p Display Replacement: étape 11, image 2 de 2
    • Remove the display from the computer.
5 autres ont terminé cette réparation.
Rasheed Adam
Membre depuis le 07/27/20
337 Réputation
1 tutoriel rédigé
Équipe
UW Tacoma, Team S1-G19, Cardinal Summer 2020 Membre de l'équipe UW Tacoma, Team S1-G19, Cardinal Summer 2020
UWT-CARDINAL-SU20S1G19
1 membre
1 tutoriel rédigé
2 commentaires
Easy peasy! Got a fresh 1080p IPS display into my ThinkPad thanks to this guide!
Noah - Réponse
What display did you have before? I have heard that there are two different display cables and if you didn't already have a 900p screen/already had a 768p screen, then you will need a new display cable to do the FHD display swap.
Annika Genisis -
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 5
7 derniers jours : 35
30 derniers jours : 96
Total : 3,023
