Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Lenovo ThinkPad T470S Batteries Replacement
Ce dont vous avez besoin
  1. Lenovo ThinkPad T470S Batteries Replacement, Bottom Panel: étape 1, image 1 de 1
    • Use a Phillips #000 screwdriver to remove the five 7 mm screws from the bottom of the laptop.
    • Lift the bottom panel up and off the laptop.
    Demander à FixBot
    Ajouter un commentaire
  2. Lenovo ThinkPad T470S Batteries Replacement, Batteries: étape 2, image 1 de 3 Lenovo ThinkPad T470S Batteries Replacement, Batteries: étape 2, image 2 de 3 Lenovo ThinkPad T470S Batteries Replacement, Batteries: étape 2, image 3 de 3
    • Remove two screws on the bottom of the upper battery using a Phillips #000 screwdriver.
    • Remove three screws on the top of the lower battery using a Phillips #000 screwdriver.
    • Peel back connecting supporting tape on each of the batteries.
    Demander à FixBot
  3. Lenovo ThinkPad T470S Batteries Replacement: étape 3, image 1 de 3 Lenovo ThinkPad T470S Batteries Replacement: étape 3, image 2 de 3 Lenovo ThinkPad T470S Batteries Replacement: étape 3, image 3 de 3
    • Slide the upper battery out of the device, away from the laptop.
    • Slide the lower battery out of the device, away from the laptop.
    Demander à FixBot
9 autres ont terminé cette réparation.
Noah Stuart
Membre depuis le 01/17/21
914 Réputation
4 tutoriels rédigés
4 commentaires de tutoriel
Is the rear battery, battery 1 or 2? It's my battery 2 that won't charge any more. But maybe I should just change them both. Do you sell both of them or just the one?
Trisha Moore - Réponse Partager
I am facing the same issue. What have u done for this... Which battery u changed the external one or internal?
Ayesha Sajid - Réponse Partager
Battery 1 (00HW023) is the larger of the two and sits under the track pad. Battery 2 (01AV406) is the smaller one and sits by the hinge to the screen.
Jesus Diaz - Réponse Partager
The original batteries have a sticker/tape to protect(?) the contacts from accidental shorting, however, the replacement batteries did not have this sticker/tape. Adding the step to transfer the tape to the new battery would be helpful.
kson2025 - Réponse Partager
Nombre de vues :
Dernières 24 heures : 24
7 derniers jours : 124
30 derniers jours : 575
Total : 51,984
