Aller au contenu principal
Lenovo ThinkPad T495 Solid State Drive (SSD) Replacement
Ce dont vous avez besoin
  1. Lenovo ThinkPad T495 Solid State Drive (SSD) Replacement, Baseplate: étape 1, image 1 de 1
    • Use a Phillips #00 screwdriver to loosen the six captive screws.
    • The screws will stay attached to the back cover as you lift it off; do not attempt to remove them.
  2. Lenovo ThinkPad T495 Solid State Drive (SSD) Replacement: étape 2, image 1 de 1
    • Use an iFixit opening tool to start prying under one of the hinges, between the baseplate and chassis, and work your way around the perimeter until the baseplate releases.
    • Lift off the baseplate.
  3. Lenovo ThinkPad T495 Solid State Drive (SSD) Replacement, Solid State Drive: étape 3, image 1 de 3 Lenovo ThinkPad T495 Solid State Drive (SSD) Replacement, Solid State Drive: étape 3, image 2 de 3 Lenovo ThinkPad T495 Solid State Drive (SSD) Replacement, Solid State Drive: étape 3, image 3 de 3
    Outil utilisé dans cette étape :
    J'achète
    • Use a Phillips #00 screwdriver to remove the 6 mm screw.
    • Use tweezers or an iFixit opening tool to lift the SSD up and away from the thermal pad it rests on.
    • Grip the SSD between your fingers and pull it horizontally to the right at a slight angle until it releases from the port.
    • The thermal pad is slightly sticky, and may stick to the bottom of the SSD as you remove it. If it does, be careful not to damage it, and make sure to reinstall the thermal pad before replacing the SSD.
Christian Taylor
Membre depuis le 03/28/22
523 Réputation
6 tutoriels rédigés
Équipe
UMass Dartmouth, Team 1-6, Petersen Spring 2022 Membre de l'équipe UMass Dartmouth, Team 1-6, Petersen Spring 2022
UMASSD-PETERSEN-S22S1G6
3 membres
7 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 6
7 derniers jours : 33
30 derniers jours : 133
Total : 2,975
