Introduction
If your laptop won't connect to Wi-Fi, the issue could be because of a damaged or broken Wi-Fi card. This guide will cover the replacement of the Wi-Fi card in the Lenovo Thinkpad T495.
Ce dont vous avez besoin
Outil utilisé dans cette étape :Tweezers$4.99
Use tweezers to lift the two coaxial cable connectors vertically, disconnecting them from the Wi-Fi card.
Use a Phillips #00 screwdriver to remove the 6 mm screw, causing the Wi-Fi card to pop up.
Presque terminé !
