Aller au contenu principal
Lenovo ThinkPad T500 Speaker Replacement
Ce dont vous avez besoin
  1. Lenovo ThinkPad T500 Speaker Replacement, Speaker: étape 1, image 1 de 1
    • Remove the eight 14mm screws using the Phillips #0 Screwdriver.
  2. Lenovo ThinkPad T500 Speaker Replacement: étape 2, image 1 de 1
    • Lift the palm rest panel up.
    • Be sure to lift the panel slowly; there is a ribbon cable attached to the bottom.
  3. Lenovo ThinkPad T500 Speaker Replacement: étape 3, image 1 de 1
    • Use the spudger to disconnect the ribbon cable.
  4. Lenovo ThinkPad T500 Speaker Replacement: étape 4, image 1 de 1
    • With the panel disconnected, lift the keyboard.
    • As with the panel, lift the keyboard slowly; there is a ribbon cable attached to the bottom.
  5. Lenovo ThinkPad T500 Speaker Replacement: étape 5, image 1 de 1
    • Disconnect the ribbon cable with the spudger.
  6. Lenovo ThinkPad T500 Speaker Replacement: étape 6, image 1 de 2 Lenovo ThinkPad T500 Speaker Replacement: étape 6, image 2 de 2
    • Remove the keyboard and the panel.
    • Using the Phillips #0 Screwdriver, remove the three 3 mm screws that are at the bottom sides and near the top-left of the speaker cover.
    • Disconnect the orange and blue cables next to the left side of the speaker cover.
  7. Lenovo ThinkPad T500 Speaker Replacement: étape 7, image 1 de 1
    • Remove the speaker cover by carefully pulling up and towards you.
  8. Lenovo ThinkPad T500 Speaker Replacement: étape 8, image 1 de 1
    • Remove the four 3mm screws on the speakers with the Phillips #0 Screwdriver.
  9. Lenovo ThinkPad T500 Speaker Replacement: étape 9, image 1 de 2 Lenovo ThinkPad T500 Speaker Replacement: étape 9, image 2 de 2
    • Using the spudger, lift the tape over the right speaker's wires.
    • Although the right speaker is unscrewed, it can't be removed from the laptop yet!
  10. Lenovo ThinkPad T500 Speaker Replacement: étape 10, image 1 de 2 Lenovo ThinkPad T500 Speaker Replacement: étape 10, image 2 de 2
    • Detach the blue and orange cables from the left speaker's clamps.
  11. Lenovo ThinkPad T500 Speaker Replacement: étape 11, image 1 de 3 Lenovo ThinkPad T500 Speaker Replacement: étape 11, image 2 de 3 Lenovo ThinkPad T500 Speaker Replacement: étape 11, image 3 de 3
    • Locate the plug in the middle of the laptop that connects both the left and right speakers.
    • Use the spudger to unplug the speaker wires.
  12. Lenovo ThinkPad T500 Speaker Replacement: étape 12, image 1 de 1
    • Remove the speakers.
nicO
Membre depuis le 04/14/15
15 927 Réputation
89 tutoriels rédigés
Équipe
Global Fixers Membre de l'équipe Global Fixers
Community
45 membres
701 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 12
30 derniers jours : 15
Total : 1,287
