Aller au contenu principal
Lenovo ThinkPad T560 Back Panel Replacement
Ce dont vous avez besoin
  1. Lenovo ThinkPad T560 Back Panel Replacement, Back Panel: étape 1, image 1 de 1
    • Before you begin this guide, make sure to disable the internal battery, power down the device and disconnect from any external power sources.
    • The external battery should be removed prior to back panel disassembly however this device doesn't have one so we aren't able to show the process.
    • Using the Phillips #0 screwdriver, remove the eight 7 mm screws holding the back panel to the T560.
  2. Lenovo ThinkPad T560 Back Panel Replacement: étape 2, image 1 de 1
    • Use the iFixit opening tool to pry the back panel off your T560.
    • Work your way around the perimeter of the device to undo the clips and detach the back panel.
Jackson Reynolds
Membre depuis le 02/27/22
517 Réputation
5 tutoriels rédigés
Équipe
Clemson, Team 1-3, Hunter Spring 2022 Membre de l'équipe Clemson, Team 1-3, Hunter Spring 2022
CLEM-HUNTER-S22S1G3
5 membres
12 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 15
30 derniers jours : 45
Total : 722
