Aller au contenu principal
Lenovo ThinkPad X1 Carbon (2nd Gen) Fan Replacement
Ce dont vous avez besoin
  1. Lenovo ThinkPad X1 Carbon (2nd Gen) Fan Replacement, Back Cover: étape 1, image 1 de 1
    • Using a Phillips #0 screwdriver, remove the seven 7mm screws holding the back cover onto your computer.
  2. Lenovo ThinkPad X1 Carbon (2nd Gen) Fan Replacement: étape 2, image 1 de 2 Lenovo ThinkPad X1 Carbon (2nd Gen) Fan Replacement: étape 2, image 2 de 2
    • Use a plastic opening tool or your fingers to pry off the cover.
  3. Lenovo ThinkPad X1 Carbon (2nd Gen) Fan Replacement, Battery: étape 3, image 1 de 2 Lenovo ThinkPad X1 Carbon (2nd Gen) Fan Replacement, Battery: étape 3, image 2 de 2
    • Using your fingers, disconnect the battery from the motherboard.
  4. Lenovo ThinkPad X1 Carbon (2nd Gen) Fan Replacement: étape 4, image 1 de 1
    • Using a Phillips #0 screwdriver, unscrew the five 4.3mm screws attaching the battery to the computer.
  5. Lenovo ThinkPad X1 Carbon (2nd Gen) Fan Replacement: étape 5, image 1 de 1
    • Remove the battery by pulling it directly towards you.
  6. Lenovo ThinkPad X1 Carbon (2nd Gen) Fan Replacement, Fan: étape 6, image 1 de 1
    • Use a Phillips #1 screwdriver to undo the four 5 mm screws attached to the heat sink.
  7. Lenovo ThinkPad X1 Carbon (2nd Gen) Fan Replacement: étape 7, image 1 de 1
    • Undo the black clasp that holds the ribbon cable, attached to the fan, in place and disconnect the ribbon cable.
  8. Lenovo ThinkPad X1 Carbon (2nd Gen) Fan Replacement: étape 8, image 1 de 1
    • Remove the fan by lifting it directly up.
2 autres ont terminé cette réparation.
Équipe
Cal Poly, Team S18-G4, White Winter 2020 Membre de l'équipe Cal Poly, Team S18-G4, White Winter 2020
CPSU-WHITE-W20S18G4
4 membres
9 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 4
30 derniers jours : 15
Total : 1,162
