Aller au contenu principal
Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement
Ce dont vous avez besoin
  1. Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement, Back Cover: étape 1, image 1 de 1
    • Using a Phillips #0 screwdriver, remove the seven 7mm screws holding the back cover onto your computer.
  2. Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement: étape 2, image 1 de 2 Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement: étape 2, image 2 de 2
    • Use a plastic opening tool or your fingers to pry off the cover.
  3. Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement, Battery: étape 3, image 1 de 2 Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement, Battery: étape 3, image 2 de 2
    • Using your fingers, disconnect the battery from the motherboard.
  4. Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement: étape 4, image 1 de 1
    • Using a Phillips #0 screwdriver, unscrew the five 4.3mm screws attaching the battery to the computer.
  5. Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement: étape 5, image 1 de 1
    • Remove the battery by pulling it directly towards you.
  6. Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement, Fan: étape 6, image 1 de 1
    • Use a Phillips #1 screwdriver to undo the four 5 mm screws attached to the heat sink.
  7. Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement: étape 7, image 1 de 1
    • Undo the black clasp that holds the ribbon cable, attached to the fan, in place and disconnect the ribbon cable.
  8. Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement: étape 8, image 1 de 1
    • Remove the fan by lifting it directly up.
  9. Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement, Motherboard: étape 9, image 1 de 2 Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement, Motherboard: étape 9, image 2 de 2
    • Disconnect all 10 of the ribbon cables attached to the motherboard.
  10. Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement: étape 10, image 1 de 2 Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement: étape 10, image 2 de 2
    • Disconnect the wire connecting the motherboard to the speaker.
  11. Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement: étape 11, image 1 de 1
    • Use a Phillips #1 screwdriver to unscrew the 4mm screw holding the metal covering over the power jack prongs.
  12. Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement: étape 12, image 1 de 1
    • Use a Phillips #1 screwdriver to unscrew the 4mm screw holding down the Micro-SD card tray.
  13. Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement: étape 13, image 1 de 2 Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement: étape 13, image 2 de 2
    • Un-tape the orange and blue wires from the motherboard.
  14. Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement: étape 14, image 1 de 1
    • Remove the black and grey wires from the cable comb on the motherboard.
  15. Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement: étape 15, image 1 de 2 Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement: étape 15, image 2 de 2
    • Use a Phillips #1 screwdriver to unscrew the 3.7mm screw holding down the wifi card.
    • Remove the wifi card.
  16. Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement: étape 16, image 1 de 2 Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement: étape 16, image 2 de 2
    • Carefully remove the motherboard by lifting it and pulling towards the left.
4 autres ont terminé cette réparation.
Eevee Murdock
Membre depuis le 01/23/20
1 086 Réputation
6 tutoriels rédigés
Équipe
Cal Poly, Team S18-G4, White Winter 2020 Membre de l'équipe Cal Poly, Team S18-G4, White Winter 2020
CPSU-WHITE-W20S18G4
4 membres
7 tutoriels rédigés
2 commentaires
All going as described, until the final step trying to pull the motherboard out, and there is something still holding it in place. With a bit of a wiggle and pull, there is something about near the screw hole that was holding the wifi card down preventing the card from lifting there. Any clues?
Tim Ellison - Réponse
Answering my own question: Removing the motherboard requires that you first pop the SIM card / MicroSD card holder out of the socket, otherwise it won’t lift out. Submitted an update to the guide to save others falling into the same trap.
Tim Ellison -
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 19
30 derniers jours : 66
Total : 3,665
