Aller au contenu principal
Lenovo ThinkPad X1 Carbon (2nd Gen) Touchpad Replacement
Ce dont vous avez besoin
  1. Lenovo ThinkPad X1 Carbon (2nd Gen) Touchpad Replacement, Back Cover: étape 1, image 1 de 1
    • Using a Phillips #0 screwdriver, remove the seven 7mm screws holding the back cover onto your computer.
  2. Lenovo ThinkPad X1 Carbon (2nd Gen) Touchpad Replacement: étape 2, image 1 de 2 Lenovo ThinkPad X1 Carbon (2nd Gen) Touchpad Replacement: étape 2, image 2 de 2
    • Use a plastic opening tool or your fingers to pry off the cover.
  3. Lenovo ThinkPad X1 Carbon (2nd Gen) Touchpad Replacement, Battery: étape 3, image 1 de 2 Lenovo ThinkPad X1 Carbon (2nd Gen) Touchpad Replacement, Battery: étape 3, image 2 de 2
    • Using your fingers, disconnect the battery from the motherboard.
  4. Lenovo ThinkPad X1 Carbon (2nd Gen) Touchpad Replacement: étape 4, image 1 de 1
    • Using a Phillips #0 screwdriver, unscrew the five 4.3mm screws attaching the battery to the computer.
  5. Lenovo ThinkPad X1 Carbon (2nd Gen) Touchpad Replacement: étape 5, image 1 de 1
    • Remove the battery by pulling it directly towards you.
  6. Lenovo ThinkPad X1 Carbon (2nd Gen) Touchpad Replacement, Touchpad: étape 6, image 1 de 1
    • Remove the black ribbon cable connected to the touchpad.
  7. Lenovo ThinkPad X1 Carbon (2nd Gen) Touchpad Replacement: étape 7, image 1 de 1
    • Use a Phillips #1 screwdriver to remove the four 1.9 mm screws holding in the touchpad.
  8. Lenovo ThinkPad X1 Carbon (2nd Gen) Touchpad Replacement: étape 8, image 1 de 1
    • Remove the touchpad by opening the computer and letting it drop onto your hand.
Eevee Murdock
Membre depuis le 01/23/20
1 086 Réputation
6 tutoriels rédigés
Équipe
Cal Poly, Team S18-G4, White Winter 2020 Membre de l'équipe Cal Poly, Team S18-G4, White Winter 2020
CPSU-WHITE-W20S18G4
4 membres
7 tutoriels rédigés
2 commentaires
Even the weirder of their models is still amazingly engineered, this was so easy to do and finding parts - not only of the same model but compatible newer parts - was an absolute breeze! Was able to upgrade my laptop during my work lunchtime, and still have time to actually eat lunch!
Casey - Réponse
Just to confirm - Thinkpad X1 Carbon Generation 3 touchpads are compatible with this model, and make for an amazing upgrade.
Casey - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 6
30 derniers jours : 35
Total : 1,717
