Aller au contenu principal
Lenovo ThinkPad X1 Carbon (2nd Gen) USB Audio Port Board Replacement
Ce dont vous avez besoin
  1. Lenovo ThinkPad X1 Carbon (2nd Gen) USB Audio Port Board Replacement, Back Cover: étape 1, image 1 de 1
    • Using a Phillips #0 screwdriver, remove the seven 7mm screws holding the back cover onto your computer.
  2. Lenovo ThinkPad X1 Carbon (2nd Gen) USB Audio Port Board Replacement: étape 2, image 1 de 2 Lenovo ThinkPad X1 Carbon (2nd Gen) USB Audio Port Board Replacement: étape 2, image 2 de 2
    • Use a plastic opening tool or your fingers to pry off the cover.
  3. Lenovo ThinkPad X1 Carbon (2nd Gen) USB Audio Port Board Replacement, Battery: étape 3, image 1 de 2 Lenovo ThinkPad X1 Carbon (2nd Gen) USB Audio Port Board Replacement, Battery: étape 3, image 2 de 2
    • Using your fingers, disconnect the battery from the motherboard.
  4. Lenovo ThinkPad X1 Carbon (2nd Gen) USB Audio Port Board Replacement: étape 4, image 1 de 1
    • Using a Phillips #0 screwdriver, unscrew the five 4.3mm screws attaching the battery to the computer.
  5. Lenovo ThinkPad X1 Carbon (2nd Gen) USB Audio Port Board Replacement: étape 5, image 1 de 1
    • Remove the battery by pulling it directly towards you.
  6. Lenovo ThinkPad X1 Carbon (2nd Gen) USB Audio Port Board Replacement, USB Audio Port Board: étape 6, image 1 de 1
    • Use a Phillips #0 screwdriver to remove the 2.9 mm screw that is holding down the USB audio port board.
  7. Lenovo ThinkPad X1 Carbon (2nd Gen) USB Audio Port Board Replacement: étape 7, image 1 de 2 Lenovo ThinkPad X1 Carbon (2nd Gen) USB Audio Port Board Replacement: étape 7, image 2 de 2
    • Undo the clasp under the USB audio port board.
  8. Lenovo ThinkPad X1 Carbon (2nd Gen) USB Audio Port Board Replacement: étape 8, image 1 de 1
    • Remove the USB audio port board from the laptop.
Eevee Murdock
Membre depuis le 01/23/20
1 086 Réputation
6 tutoriels rédigés
Équipe
Cal Poly, Team S18-G4, White Winter 2020 Membre de l'équipe Cal Poly, Team S18-G4, White Winter 2020
CPSU-WHITE-W20S18G4
4 membres
9 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 11
Total : 990
