Introduction
This guide will cover how to remove and replace the fan in the Lenovo ThinkPad X1 Carbon 6th Gen. This may be necessary if you need to access the fan for cleaning, or if you need to replace a broken or faulty fan. It is important for your fan to work properly because it prevents overheating which may damage your laptop. If you are having trouble with your computer fan, consult our troubleshooting page. Before beginning, be sure to power off your laptop and disconnect it from any power source.
Ce dont vous avez besoin
Use a Phillips #0 screwdriver to unscrew the five screws that secure the back cover to the laptop.
Use a Phillips #0 screwdriver to loosen the four screws that secure the fan to the motherboard.
Use nylon tipped tweezers, or your fingers, to gently pull the fan's power cable towards the SSD, disconnecting it from the pins.
4 autres ont terminé cette réparation.
