Aller au contenu principal
Lenovo ThinkPad X1 Extreme Hinges Replacement
Ce dont vous avez besoin
  1. Lenovo ThinkPad X1 Extreme Hinges Replacement, Back Cover: étape 1, image 1 de 3 Lenovo ThinkPad X1 Extreme Hinges Replacement, Back Cover: étape 1, image 2 de 3 Lenovo ThinkPad X1 Extreme Hinges Replacement, Back Cover: étape 1, image 3 de 3
    • Power off and unplug your device before you begin.
    • Orient the laptop so that it is bottom up, and the trackpad is closest to you.
    • Unscrew the seven captive screws with a Phillips #00 screwdriver.
    • These screws will loosen, but stay attached to the cover. Do not attempt to completely remove them.
    • Slide a blue opening pick in the gap between the bottom panel and chassis, and pry off the one clip on each side.
    • Remove the back cover from the device.
  2. Lenovo ThinkPad X1 Extreme Hinges Replacement, Speakers: étape 2, image 1 de 1
    • Use a Phillips #00 head screwdriver to remove the four 4 mm screws above the battery.
  3. Lenovo ThinkPad X1 Extreme Hinges Replacement: étape 3, image 1 de 1
    • Lift the speaker modules on either side of the battery out of its pegs, and unwind the cable from the front of the battery.
    • Set the speaker modules out of the way.
  4. Lenovo ThinkPad X1 Extreme Hinges Replacement, Battery: étape 4, image 1 de 3 Lenovo ThinkPad X1 Extreme Hinges Replacement, Battery: étape 4, image 2 de 3 Lenovo ThinkPad X1 Extreme Hinges Replacement, Battery: étape 4, image 3 de 3
    Outil utilisé dans cette étape :
    J'achète
    • Use tweezers to peel the plastic cover off the connector.
    • Use a spudger or your fingernail to pry up the battery straight up from the motherboard.
  5. Lenovo ThinkPad X1 Extreme Hinges Replacement: étape 5, image 1 de 1
    • Lift the battery out of the frame and remove it from the device.
  6. Lenovo ThinkPad X1 Extreme Hinges Replacement, Hinges: étape 6, image 1 de 3 Lenovo ThinkPad X1 Extreme Hinges Replacement, Hinges: étape 6, image 2 de 3 Lenovo ThinkPad X1 Extreme Hinges Replacement, Hinges: étape 6, image 3 de 3
    • Remove back panel and locate the connecting wires.
    • Disconnect the display connections on the motherboard.
    • Use a Phillips #00 screwdriver to remove the six screws (three on each hinge) securing the hinges to the main chassis.
  7. Lenovo ThinkPad X1 Extreme Hinges Replacement: étape 7, image 1 de 3 Lenovo ThinkPad X1 Extreme Hinges Replacement: étape 7, image 2 de 3 Lenovo ThinkPad X1 Extreme Hinges Replacement: étape 7, image 3 de 3
    • Flip the display face up, then wedge a Jimmy between the display and the bezel, sliding and prying around the perimeter until the bezel releases.
    • Unscrew the first two exposed 1.2 mm screws with a Phillips #1 screwdriver, then peel back the adhesive to find and remove the third screw.
    • Lift the hinges up and off the display.
Alma Orozco-Rico
Membre depuis le 02/10/22
85 Réputation
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 21
Total : 900
