Aller au contenu principal
Lenovo ThinkPad X1 Extreme SSD Replacement
Ce dont vous avez besoin
  1. Lenovo ThinkPad X1 Extreme SSD Replacement, Back Cover: étape 1, image 1 de 3 Lenovo ThinkPad X1 Extreme SSD Replacement, Back Cover: étape 1, image 2 de 3 Lenovo ThinkPad X1 Extreme SSD Replacement, Back Cover: étape 1, image 3 de 3
    • Power off and unplug your device before you begin.
    • Orient the laptop so that it is bottom up, and the trackpad is closest to you.
    • Unscrew the seven captive screws with a Phillips #00 screwdriver.
    • These screws will loosen, but stay attached to the cover. Do not attempt to completely remove them.
    • Slide a blue opening pick in the gap between the bottom panel and chassis, and pry off the one clip on each side.
    • Remove the back cover from the device.
  2. Lenovo ThinkPad X1 Extreme SSD Replacement, SSD: étape 2, image 1 de 2 Lenovo ThinkPad X1 Extreme SSD Replacement, SSD: étape 2, image 2 de 2
    • Using the Phillips #00 screwdriver, remove the single screw securing the SSD to the motherboard.
  3. Lenovo ThinkPad X1 Extreme SSD Replacement: étape 3, image 1 de 2 Lenovo ThinkPad X1 Extreme SSD Replacement: étape 3, image 2 de 2
    • Using the opening tool, pop out the SSD card and remove it from the device.
Un commentaire
Anyhow this laptop support gen 4 nvme or higher?
jordan chong - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 10
30 derniers jours : 51
Total : 1,997
