Aller au contenu principal
Lenovo ThinkPad X1 Yoga 2nd Generation Trackpad Replacement
Ce dont vous avez besoin
  1. Lenovo ThinkPad X1 Yoga 2nd Generation Trackpad Replacement, Back Cover: étape 1, image 1 de 1
    • Ensure the laptop is powered off and the charging cable is disconnected before opening the back cover.
    • Flip over the laptop to access the back cover.
  2. Lenovo ThinkPad X1 Yoga 2nd Generation Trackpad Replacement: étape 2, image 1 de 2 Lenovo ThinkPad X1 Yoga 2nd Generation Trackpad Replacement: étape 2, image 2 de 2
    • Use a Phillips #0 screwdriver to remove the eight 8 mm screws.
  3. Lenovo ThinkPad X1 Yoga 2nd Generation Trackpad Replacement: étape 3, image 1 de 1
    • Remove the back cover.
    • A popping sound may occur when the back cover is removed.
  4. Lenovo ThinkPad X1 Yoga 2nd Generation Trackpad Replacement, Speakers: étape 4, image 1 de 2 Lenovo ThinkPad X1 Yoga 2nd Generation Trackpad Replacement, Speakers: étape 4, image 2 de 2
    Outil utilisé dans cette étape :
    $3.99
    • Follow the ribbon cable that runs from the left speaker to the motherboard.
    • Pull the black connector up and release the cable wire by hand.
    • If needed, pull this connector up using the Pro/ESD/angled tweezers.
  5. Lenovo ThinkPad X1 Yoga 2nd Generation Trackpad Replacement: étape 5, image 1 de 2 Lenovo ThinkPad X1 Yoga 2nd Generation Trackpad Replacement: étape 5, image 2 de 2
    • Remove two 6 mm Phillips #0 screws from each speaker.
  6. Lenovo ThinkPad X1 Yoga 2nd Generation Trackpad Replacement: étape 6, image 1 de 2 Lenovo ThinkPad X1 Yoga 2nd Generation Trackpad Replacement: étape 6, image 2 de 2
    • Use your fingers to remove the speakers from the device.
  7. Lenovo ThinkPad X1 Yoga 2nd Generation Trackpad Replacement, Battery: étape 7, image 1 de 1
    • Use a spudger to pop the ribbon cable that runs from the upper-middle portion of the battery to the motherboard out of the motherboard.
    • Do not use a metal spudger as indicated in the photos. The metal spudger should only be used for serious prying power. If it's used on the internal components of a device, it may puncture or damage the components in your device.
  8. Lenovo ThinkPad X1 Yoga 2nd Generation Trackpad Replacement: étape 8, image 1 de 1
    • Use a Phillips #0 screwdriver to remove one 6 mm screw from the bottom-middle portion of the battery.
  9. Lenovo ThinkPad X1 Yoga 2nd Generation Trackpad Replacement: étape 9, image 1 de 1
    • Remove the battery.
  10. Lenovo ThinkPad X1 Yoga 2nd Generation Trackpad Replacement, Trackpad: étape 10, image 1 de 2 Lenovo ThinkPad X1 Yoga 2nd Generation Trackpad Replacement, Trackpad: étape 10, image 2 de 2
    • Using a Phillips #0 screwdriver, remove four 3 mm screws.
  11. Lenovo ThinkPad X1 Yoga 2nd Generation Trackpad Replacement: étape 11, image 1 de 1
    • Lift up the laptop and remove the trackpad from the device.
    • When you lift up the bottom panel, the trackpad should fall from the device.
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 9
Total : 617
