Aller au contenu principal
Lenovo ThinkPad X1 Yoga Keyboard Replacement
Ce dont vous avez besoin
  1. Lenovo ThinkPad X1 Yoga Keyboard Replacement, Back Cover: étape 1, image 1 de 3 Lenovo ThinkPad X1 Yoga Keyboard Replacement, Back Cover: étape 1, image 2 de 3 Lenovo ThinkPad X1 Yoga Keyboard Replacement, Back Cover: étape 1, image 3 de 3
    • Be sure to power off and unplug your device before you begin your repair.
    • Flip the computer over so the bottom is facing up.
    • Remove nine 4mm Phillips #1 screws from the bottom of the computer.
    • Use an iFixit opening tool to pry the back cover off of the laptop.
  2. Lenovo ThinkPad X1 Yoga Keyboard Replacement, Speakers: étape 2, image 1 de 1
    • Remove the five 4.5mm Phillips #1 screws that secure the battery.
  3. Lenovo ThinkPad X1 Yoga Keyboard Replacement: étape 3, image 1 de 1
    Outil utilisé dans cette étape :
    • Using a pair of tweezers, push the sides of the white speaker wire toward the battery (where it says Lenovo) to unplug it.
  4. Lenovo ThinkPad X1 Yoga Keyboard Replacement: étape 4, image 1 de 3 Lenovo ThinkPad X1 Yoga Keyboard Replacement: étape 4, image 2 de 3 Lenovo ThinkPad X1 Yoga Keyboard Replacement: étape 4, image 3 de 3
    • Remove the speakers from either side of the battery. The connecting wire will unthread from the sides of the battery.
  5. Lenovo ThinkPad X1 Yoga Keyboard Replacement, Battery: étape 5, image 1 de 3 Lenovo ThinkPad X1 Yoga Keyboard Replacement, Battery: étape 5, image 2 de 3 Lenovo ThinkPad X1 Yoga Keyboard Replacement, Battery: étape 5, image 3 de 3
    • Lift the plastic black strip cover that's laying over the battery connector.
    • Use the iFixit opening tool to flip up and disconnect the black battery connector from its motherboard socket.
    • Gently pull the connector away from the battery to pull it out of the slot.
  6. Lenovo ThinkPad X1 Yoga Keyboard Replacement: étape 6, image 1 de 1
    • Lift and remove the battery away from the computer.
  7. Lenovo ThinkPad X1 Yoga Keyboard Replacement, Cooling Fan: étape 7, image 1 de 1
    • Remove four 4.5mm Phillips #1 screws from the corners of the heat sink.
  8. Lenovo ThinkPad X1 Yoga Keyboard Replacement: étape 8, image 1 de 3 Lenovo ThinkPad X1 Yoga Keyboard Replacement: étape 8, image 2 de 3 Lenovo ThinkPad X1 Yoga Keyboard Replacement: étape 8, image 3 de 3
    • Gently peel back the black plastic covering around the fan.
    • You may hear or feel the adhesive pulling away here.
    • Using an iFixit opening tool, flip up the small black cover of the fan plug.
  9. Lenovo ThinkPad X1 Yoga Keyboard Replacement: étape 9, image 1 de 2 Lenovo ThinkPad X1 Yoga Keyboard Replacement: étape 9, image 2 de 2
    • Using tweezers, pull the plastic strip out.
  10. Lenovo ThinkPad X1 Yoga Keyboard Replacement: étape 10, image 1 de 2 Lenovo ThinkPad X1 Yoga Keyboard Replacement: étape 10, image 2 de 2
    • Remove the fan from the computer.
  11. Lenovo ThinkPad X1 Yoga Keyboard Replacement, Wireless chip: étape 11, image 1 de 1
    • Gently peel back the black plastic covering.
    • Remove the single Phillips #1 screw securing the wireless chip in place.
  12. Lenovo ThinkPad X1 Yoga Keyboard Replacement: étape 12, image 1 de 2 Lenovo ThinkPad X1 Yoga Keyboard Replacement: étape 12, image 2 de 2
    • Use an iFixit opening tool to gently pop the gold caps off their connections.
    • Move these wires out of the way.
  13. Lenovo ThinkPad X1 Yoga Keyboard Replacement: étape 13, image 1 de 1
    • Slide the chip out.
  14. Lenovo ThinkPad X1 Yoga Keyboard Replacement, Hard Drive: étape 14, image 1 de 2 Lenovo ThinkPad X1 Yoga Keyboard Replacement, Hard Drive: étape 14, image 2 de 2
    • Remove the single 2mm Phillips #1 screw from the hard drive's silver casing.
  15. Lenovo ThinkPad X1 Yoga Keyboard Replacement: étape 15, image 1 de 1
    • Unplug the hard drive from the computer by pulling away from the computer.
  16. Lenovo ThinkPad X1 Yoga Keyboard Replacement, Motherboard: étape 16, image 1 de 3 Lenovo ThinkPad X1 Yoga Keyboard Replacement, Motherboard: étape 16, image 2 de 3 Lenovo ThinkPad X1 Yoga Keyboard Replacement, Motherboard: étape 16, image 3 de 3
    • Using the iFixit opening tool, flip up the eight small covers from the cable connectors.
    • Gently pull the cables out of the slots.
  17. Lenovo ThinkPad X1 Yoga Keyboard Replacement: étape 17, image 1 de 2 Lenovo ThinkPad X1 Yoga Keyboard Replacement: étape 17, image 2 de 2
    • Using the Phillips #1 screwdriver, remove sixteen 4.5mm screws.
  18. Lenovo ThinkPad X1 Yoga Keyboard Replacement: étape 18, image 1 de 1
    • Lift and remove the motherboard away from the computer.
  19. Lenovo ThinkPad X1 Yoga Keyboard Replacement, Keyboard: étape 19, image 1 de 2 Lenovo ThinkPad X1 Yoga Keyboard Replacement, Keyboard: étape 19, image 2 de 2
    • Using the Phillips #1 screwdriver, remove 23 (twenty three) 4.5mm screws.
  20. Lenovo ThinkPad X1 Yoga Keyboard Replacement: étape 20, image 1 de 1
    • Using the iFixit opening tool, lift the metal frame away from the keyboard.
  21. Lenovo ThinkPad X1 Yoga Keyboard Replacement: étape 21, image 1 de 1
    • Lift and remove the keyboard away from the computer.
9 autres ont terminé cette réparation.
2 commentaires
Samw steps on gen 4, screws just in different places, thie guide worked great! Thanks :)
Ryan B - Réponse
there's no need to remove the heat sink, SSD and wireless cards - you can just remove the motherboard in 1 piece with these still attached.
Slim - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 35
30 derniers jours : 244
Total : 15,520
