Aller au contenu principal
Lenovo ThinkPad X100e Screen Replacement
Ce dont vous avez besoin
  1. Lenovo ThinkPad X100e Screen Replacement, Screen: étape 1, image 1 de 2 Lenovo ThinkPad X100e Screen Replacement, Screen: étape 1, image 2 de 2
    Outil utilisé dans cette étape :
    Spudger
    $2.99
    • Use a Spudger tool to remove the screw covers on each side of the screen.
    • Be sure not to lose screw covers.
  2. Lenovo ThinkPad X100e Screen Replacement: étape 2, image 1 de 1
    • Using a magnetic screwdriver fit with a PH0 Bit, unscrew the two screws and carefully set the aside.
  3. Lenovo ThinkPad X100e Screen Replacement: étape 3, image 1 de 1
    • Pry open the bezel carefully with the spudger tool.
    • You will want to do this until the frame is completely off.
  4. Lenovo ThinkPad X100e Screen Replacement: étape 4, image 1 de 1
    • Remove all exposed screws and carefully set them aside. There should be 6 visible screws.
    • Be sure to set the screws aside on the magnetic mat.
  5. Lenovo ThinkPad X100e Screen Replacement: étape 5, image 1 de 1
    • Lift the screen up carefully, and remove the screws on both sides of the panel. There should be 4 screws.
    • The other two screws are located in the exact place on the other side.
    • Don't forget to place the screws on the magnetic mat, separate from other screws.
  6. Lenovo ThinkPad X100e Screen Replacement: étape 6, image 1 de 2 Lenovo ThinkPad X100e Screen Replacement: étape 6, image 2 de 2
    • Remove the connector located at the very top of the screen beside the webcam.
    • To remove the connector, simply pull the connector out.
  7. Lenovo ThinkPad X100e Screen Replacement: étape 7, image 1 de 1
    • Fold the panel over until a strip of black tape is visible.
    • Peel the tape down until you get to the base.
  8. Lenovo ThinkPad X100e Screen Replacement: étape 8, image 1 de 2 Lenovo ThinkPad X100e Screen Replacement: étape 8, image 2 de 2
    • Peel the piece of transparent tape back.
    • At this point there should be some exposed wires underneath the tape.
  9. Lenovo ThinkPad X100e Screen Replacement: étape 9, image 1 de 1
    • Remove the connector carefully with the spudger tool.
  10. Lenovo ThinkPad X100e Screen Replacement: étape 10, image 1 de 1
    • Remove the black tape fully.
    • Now your device is ready for a new panel.
Orly Guerra
Membre depuis le 02/08/18
448 Réputation
2 tutoriels rédigés
Équipe
Un commentaire
What can be used as a replacement screen, as it's listed not for sale?
Keith Bowe - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 15
30 derniers jours : 19
Total : 908
