Aller au contenu principal
Lenovo ThinkPad X140e Battery Replacement
Ce dont vous avez besoin
  1. Lenovo ThinkPad X140e Battery Replacement, Battery: étape 1, image 1 de 1
    • Turn off your laptop and unplug the charging cable.
    • Failure to remove the charging cable may cause electric shock.
    • Flip the laptop upside down.
    • Rotate the laptop so that the battery is facing away from you.
  2. Lenovo ThinkPad X140e Battery Replacement: étape 2, image 1 de 1
    • Push the first switch on the left to the right until you hear a click. This means the battery is unlocked and can be removed.
  3. Lenovo ThinkPad X140e Battery Replacement: étape 3, image 1 de 2 Lenovo ThinkPad X140e Battery Replacement: étape 3, image 2 de 2
    • Push the second switch on the right to the right, hold it there with your right hand and continue to the next step.
    • While holding the right switch open, take your free hand and pull the battery out.
Dylan Halland
Membre depuis le 10/05/16
324 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 20-5, Livingston Fall 2016 Membre de l'équipe Cal Poly, Team 20-5, Livingston Fall 2016
CPSU-LIVINGSTON-F16S20G5
4 membres
5 tutoriels rédigés
Un commentaire
I did this, but the computer says that the battery is not genuine, and then refuses to charge the battery. What do I do?
Justine Akehurst - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 9
30 derniers jours : 16
Total : 1,062
