Aller au contenu principal
Introduction
Having a problem with Hard Disk in your Lenovo X240 ? Follow along while we show you how to get it replaced! All you need is your iFixit Toolkit.
  1. Flip the laptop upside down as shown in the photo.
    • Flip the laptop upside down as shown in the photo.
  2. Remove the 8 0.2mm Phillips screws connecting the back cover to the laptop. Remove the 8 0.2mm Phillips screws connecting the back cover to the laptop.
    • Remove the 8 0.2mm Phillips screws connecting the back cover to the laptop.
  3. Remove the back cover using the opening tools.
    • Remove the back cover using the opening tools.
    • Gently use the plastic opening tools to prevent scratching your device.
  4. Remove the Hard Disk Drive card by  screwing the 2 0.2mm Phillips screw
    • Remove the Hard Disk Drive card by screwing the 2 0.2mm Phillips screw
  5. Disconnect the SATA cable from the hard drive.
    • Disconnect the SATA cable from the hard drive.
  6. Take off the connector by carefully popping its holders out of place
    • Take off the connector by carefully popping its holders out of place
  7. Reconnect  the cable to the new Hard Disk Drive
    • Reconnect the cable to the new Hard Disk Drive
  8. place the connector in order to hold the cable
    • place the connector in order to hold the cable
  9. Place the new Hard Drive Disk
    • Place the new Hard Drive Disk
8 autres ont terminé cette réparation.
Mohammed Alsaadi
Membre depuis le 20/09/2017
522 Réputation
2 tutoriels rédigés
Équipe
3 commentaires
Hello, i think you forgot to disconnect internal battery first before you replace something
shofaribagus - Réponse
Tip for the case screws, they are captive don’t worry about them
Baddo-M _ - Réponse
Yes, good point - case screws are captive and easy to keep in place when lifting the cover. But overall this is a well written guide, so thanks for this.
Ricky Las Vegas - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 5
7 derniers jours : 31
30 derniers jours : 148
Total : 12,191
