Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Lenovo ThinkPad X260 Internal Battery Replacement
Ce dont vous avez besoin
  1. Lenovo ThinkPad X260 Internal Battery Replacement, External Battery: étape 1, image 1 de 2 Lenovo ThinkPad X260 Internal Battery Replacement, External Battery: étape 1, image 2 de 2
    • Make sure that the device is unplugged and turned off.
    • Flip the laptop from the front to the back.
  2. Lenovo ThinkPad X260 Internal Battery Replacement: étape 2, image 1 de 3 Lenovo ThinkPad X260 Internal Battery Replacement: étape 2, image 2 de 3 Lenovo ThinkPad X260 Internal Battery Replacement: étape 2, image 3 de 3
    • Start by pinching the switches on either side of the battery outwards.
    • At the same time push the external battery, located in the back, upwards.
    • Remove the external battery from the laptop.
  3. Lenovo ThinkPad X260 Internal Battery Replacement, Back Cover: étape 3, image 1 de 3 Lenovo ThinkPad X260 Internal Battery Replacement, Back Cover: étape 3, image 2 de 3 Lenovo ThinkPad X260 Internal Battery Replacement, Back Cover: étape 3, image 3 de 3
    • Loosen the eight 4.2 mm screws holding the back cover on using a Phillips #1 screwdriver.
    • These screws should be held in place by a small plastic washer which secures them to the cover and should not be loosened. This is illustrated in the third image.
  4. Lenovo ThinkPad X260 Internal Battery Replacement: étape 4, image 1 de 3 Lenovo ThinkPad X260 Internal Battery Replacement: étape 4, image 2 de 3 Lenovo ThinkPad X260 Internal Battery Replacement: étape 4, image 3 de 3
    • Gently pull the cover off and set aside.
    • An iFixit opening tool may make it easier to gently remove the cover.
  5. Lenovo ThinkPad X260 Internal Battery Replacement, Internal Battery: étape 5, image 1 de 2 Lenovo ThinkPad X260 Internal Battery Replacement, Internal Battery: étape 5, image 2 de 2
    Outil utilisé dans cette étape :
    • Detach the black battery connector using a pair of tweezers.
  6. Lenovo ThinkPad X260 Internal Battery Replacement: étape 6, image 1 de 1
    • Remove the four 3.3 mm screws locking down the battery using a Phillips #1 screwdriver.
  7. Lenovo ThinkPad X260 Internal Battery Replacement: étape 7, image 1 de 3 Lenovo ThinkPad X260 Internal Battery Replacement: étape 7, image 2 de 3 Lenovo ThinkPad X260 Internal Battery Replacement: étape 7, image 3 de 3
    • Carefully remove the internal battery unit from the laptop using an iFixit opening tool.
    • Pick up the battery and take it off the laptop frame.
Ammarin Sinthana
Membre depuis le 07/13/23
125 Réputation
1 tutoriel rédigé
Équipe
IUPUI, Team 1-3, Harley Summer 2023 Membre de l'équipe IUPUI, Team 1-3, Harley Summer 2023
IUPUI-HARLEY-SU23S1G3
3 membres
4 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 27
30 derniers jours : 160
Total : 4,150
