Aller au contenu principal
Lenovo ThinkPad X280 Wi-Fi Card Replacement
Ce dont vous avez besoin
  1. Lenovo ThinkPad X280 Wi-Fi Card Replacement, Back Panel: étape 1, image 1 de 1
    • To begin, ensure that the device is completely powered off and not connected to an energy supply.
    • Close the device and flip it over to expose the back panel.
  2. Lenovo ThinkPad X280 Wi-Fi Card Replacement: étape 2, image 1 de 2 Lenovo ThinkPad X280 Wi-Fi Card Replacement: étape 2, image 2 de 2
    • Use a Phillips #1 screwdriver to unscrew the five captive screws on the back panel until a small pop is heard.
    • These are captive screws and do not come out completely.
  3. Lenovo ThinkPad X280 Wi-Fi Card Replacement: étape 3, image 1 de 2 Lenovo ThinkPad X280 Wi-Fi Card Replacement: étape 3, image 2 de 2
    • Gently wedge an opening tool or spudger under the back panel, and loosen the clips around the perimeter until the back panel comes off.
    • Remove the back cover.
  4. Lenovo ThinkPad X280 Wi-Fi Card Replacement, Wi-Fi Card: étape 4, image 1 de 1
    Outil utilisé dans cette étape :
    • Use tweezers to gently disconnect the two wires that are connected to the Wi-Fi card.
    • They should pop off with minimal force.
  5. Lenovo ThinkPad X280 Wi-Fi Card Replacement: étape 5, image 1 de 1
    • Use a Phillips #1 screwdriver to remove the single screw that secures the Wi-Fi card.
    • Be careful not to over-tighten the screw when reassembling, should be thumb tight
  6. Lenovo ThinkPad X280 Wi-Fi Card Replacement: étape 6, image 1 de 1
    • Use tweezers or your fingers to gently pull the Wi-Fi card from its port.
    • Pull directly away from the port, parallel with the card. Do not pull up towards yourself.
2 autres ont terminé cette réparation.
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 5
7 derniers jours : 16
30 derniers jours : 35
Total : 1,446
