Introduction
If you need to access your laptops touchpad please refer to this guide. This guide does not require any difficult or complicated steps. Do exercise caution before beginning this guide by ensuring that the laptop is unplugged and turned off. To complete the replacement of your touchpad, you will need a plastic opening tool, a Phillips #0 screwdriver, a pair of tweezers, and a plastic scalpel.
Ce dont vous avez besoin
Flip your laptop over and place on a flat surface so you can access the screws on the base cover.
Using a Phillips #0 screwdriver, unscrew the five screws on the base cover.
Outil utilisé dans cette étape :Tweezers$4.99
Using tweezers, unplug the battery from the laptops motherboard by pulling on the cable that attaches it.
After removing the battery, disconnect the trackpad from the laptop's motherboard
Using a plastic spudger, flip up the black plastic cover to release the cable.
