Aller au contenu principal
Lenovo ThinkPad X390 Yoga Speakers Replacement
Ce dont vous avez besoin
  1. Lenovo ThinkPad X390 Yoga Speakers Replacement, Back Case: étape 1, image 1 de 1
    • Safety Procedures:
    • Shutdown and Disable Power Supply: 1. Disconnect adapter. 2. Press F1 key to enter BIOS setup powering up Laptop. 3. Go to Configuration menu. 4. Select Power and press Enter. 5. Highlight Disable Built-in Battery and press Enter. 6. Confirm by selecting "Yes" and pressing Enter. 7. System will power down, and disabled battery.
    • Electrostatic Discharge (ESD) Safety: 1. Ground yourself to prevent static damage by wearing an ESD wrist strap or touching a grounded metal surface.
    • Remove the SIM Card Tray 1. Insert a straightened paperclip into the hole on the SIM card tray. 2. Gently push to eject and remove the tray.
    • Use a Phillips #1 screwdriver to unscrew the captive screws from the back of the device. The screws should not be removed from the back panel, so don't try to force them out.
    • Disassemble the Laptop: Remove the Bottom Cover and Battery: 1. Loosen five captive screws on bottom of laptop. 2. Use a non-metallic pry tool to carefully loosen clips along the rear cover. 3. Lift and remove bottom cover. 4. Disconnect internal battery cable from system board. 5. Remove five screws securing the battery and lift it out of system.
  2. Lenovo ThinkPad X390 Yoga Speakers Replacement: étape 2, image 1 de 1
    • Use the iFixit opening tool to remove the back case by entering the tip of the tool into the seam and prying up.
    • This can be tough so take your time to undo the clips around the perimeter before removing the back cover.
    • Disconnect Screen Cables: 1. Disconnect the LED camera cable and remove it from its guide. 2. Remove the antenna cables from their guides. 3. Disconnect the LCD cable and remove it from its guide. 4. Remove the Antenna Cables from the guide which is next to LCD cable. 5. Remove three screws from each hinge.
  3. Lenovo ThinkPad X390 Yoga Speakers Replacement: étape 3, image 1 de 1
    • Once the back cover is no longer attached carefully remove it by lifting straight up.
  4. Lenovo ThinkPad X390 Yoga Speakers Replacement, Battery: étape 4, image 1 de 1
    • Use the spudger to disconnect the battery from the motherboard at the connector socket.
  5. Lenovo ThinkPad X390 Yoga Speakers Replacement: étape 5, image 1 de 1
    • Use the Phillips #1 screwdriver to remove five 4 mm screws around the battery.
  6. Lenovo ThinkPad X390 Yoga Speakers Replacement: étape 6, image 1 de 1
    • Lift the battery out of the laptop by lifting up.
  7. Lenovo ThinkPad X390 Yoga Speakers Replacement, Speaker: étape 7, image 1 de 1
    • Disconnect the connector wire by gently pulling away from the port.
  8. Lenovo ThinkPad X390 Yoga Speakers Replacement: étape 8, image 1 de 1
    • Remove the speaker by lifting them up.
    • Gently lift the speaker cable that connects the two speakers from the perimeter of the chassis.
Tanner Baine
Membre depuis le 09/03/21
423 Réputation
4 tutoriels rédigés
Équipe
University of Alabama, Team 1-2, Bedsole Fall 2021 Membre de l'équipe University of Alabama, Team 1-2, Bedsole Fall 2021
UA-BEDSOLE-F21S1G2
4 membres
12 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 12
30 derniers jours : 23
Total : 495
