Aller au contenu principal
Lenovo ThinkPad X390 Yoga Touchpad Replacement
Ce dont vous avez besoin
  1. Lenovo ThinkPad X390 Yoga Touchpad Replacement, Back Case: étape 1, image 1 de 1
    • Use a Phillips #1 screwdriver to unscrew the eight captive screws from the back of the device.
    • The screws should not be removed from the back panel, so don't try to force them out.
  2. Lenovo ThinkPad X390 Yoga Touchpad Replacement: étape 2, image 1 de 1
    • Use the iFixit opening tool to remove the back case by entering the tip of the tool into the seam and prying up.
    • This can be tough so take your time to undo the clips around the perimeter before removing the back cover.
  3. Lenovo ThinkPad X390 Yoga Touchpad Replacement: étape 3, image 1 de 1
    • Once the back cover is no longer attached carefully remove it by lifting straight up.
  4. Lenovo ThinkPad X390 Yoga Touchpad Replacement, Battery: étape 4, image 1 de 1
    • Use the spudger to disconnect the battery from the motherboard at the connector socket.
  5. Lenovo ThinkPad X390 Yoga Touchpad Replacement: étape 5, image 1 de 1
    • Use the Phillips #1 screwdriver to remove five 4 mm screws around the battery.
  6. Lenovo ThinkPad X390 Yoga Touchpad Replacement: étape 6, image 1 de 1
    • Lift the battery out of the laptop by lifting up.
  7. Lenovo ThinkPad X390 Yoga Touchpad Replacement, Touchpad: étape 7, image 1 de 1
    • Disconnect the touchpad ribbon connector from the motherboard using the opening tool.
  8. Lenovo ThinkPad X390 Yoga Touchpad Replacement: étape 8, image 1 de 1
    • Remove the four 4 mm screws using the Phillips #1 screwdriver.
  9. Lenovo ThinkPad X390 Yoga Touchpad Replacement: étape 9, image 1 de 1
    • Carefully open the laptop and remove the touchpad.
Tanner Baine
Membre depuis le 09/03/21
423 Réputation
4 tutoriels rédigés
Équipe
University of Alabama, Team 1-2, Bedsole Fall 2021 Membre de l'équipe University of Alabama, Team 1-2, Bedsole Fall 2021
UA-BEDSOLE-F21S1G2
4 membres
12 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 33
Total : 683
