Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Lenovo ThinkPad Yoga 14 20FY Hard Drive Replacement
Ce dont vous avez besoin
    1. Lenovo ThinkPad Yoga 14 20FY Hard Drive  Replacement, Back Cover: étape 1, image 1 de 2 Lenovo ThinkPad Yoga 14 20FY Hard Drive  Replacement, Back Cover: étape 1, image 2 de 2
      • Remove the indicated nine M2 x 6 mm nylon-coated screws using a Phillips head screwdriver.
      • The screws do not come all the way out. Do not force them out.
      Demander à FixBot
      Ajouter un commentaire
    2. Lenovo ThinkPad Yoga 14 20FY Hard Drive  Replacement: étape 2, image 1 de 2 Lenovo ThinkPad Yoga 14 20FY Hard Drive  Replacement: étape 2, image 2 de 2
      • After removing all of the screws, gently lift up on all covers to remove the back plate and reveal the interior of the device.
      Demander à FixBot
    1. Lenovo ThinkPad Yoga 14 20FY Hard Drive  Replacement, Hard Drive: étape 3, image 1 de 2 Lenovo ThinkPad Yoga 14 20FY Hard Drive  Replacement, Hard Drive: étape 3, image 2 de 2
      • Once the back cover is exposed, remove the two screws holding the hard drive in place.
      Demander à FixBot
    2. Lenovo ThinkPad Yoga 14 20FY Hard Drive  Replacement: étape 4, image 1 de 1
      • Remove the plastic encasing holding down the hard drive after screws are removed.
      • This is the plastic encasing covering the SATA connection on the hard drive. There will be another plastic encasing that will be required to remove in a later step.
      Demander à FixBot
    3. Lenovo ThinkPad Yoga 14 20FY Hard Drive  Replacement: étape 5, image 1 de 2 Lenovo ThinkPad Yoga 14 20FY Hard Drive  Replacement: étape 5, image 2 de 2
      • Using two fingers, carefully remove the hard drive.
      Demander à FixBot
    4. Lenovo ThinkPad Yoga 14 20FY Hard Drive  Replacement: étape 6, image 1 de 2 Lenovo ThinkPad Yoga 14 20FY Hard Drive  Replacement: étape 6, image 2 de 2
      • Carefully remove the plastic encasing surrounding the perimeter of the hard drive.
      Demander à FixBot
    5. Lenovo ThinkPad Yoga 14 20FY Hard Drive  Replacement: étape 7, image 1 de 3 Lenovo ThinkPad Yoga 14 20FY Hard Drive  Replacement: étape 7, image 2 de 3 Lenovo ThinkPad Yoga 14 20FY Hard Drive  Replacement: étape 7, image 3 de 3
      • This step requires the most precision. Forcefully using the prying tool to remove the SATA connector may damage the hard drive and the connection. Remove the connection slowly to a point where you can safely finish removing the connection with your fingers.
      • Use a nylon spudger to remove the SATA connector from the hard drive.
      Demander à FixBot
    6. Lenovo ThinkPad Yoga 14 20FY Hard Drive  Replacement: étape 8, image 1 de 2 Lenovo ThinkPad Yoga 14 20FY Hard Drive  Replacement: étape 8, image 2 de 2
      • After the SATA connection is removed, gently pop off the hard drive from its socket.
      Demander à FixBot
5 autres ont terminé cette réparation.
Richard Terre
Membre depuis le 04/19/17
244 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team S14-G2, Banghart Spring 2017 Membre de l'équipe Cal Poly, Team S14-G2, Banghart Spring 2017
CPSU-BANGHART-S17S14G2
5 membres
72 tutoriels rédigés
1 commentaire de tutoriel
jhonson - Réponse Partager
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 9
30 derniers jours : 33
Total : 5,787
