Aller au contenu principal
Introduction
The back cover protects all the internal hardware of the device. In order to replace any components, the back cover must be removed. This guide will highlight how to remove the back cover safely.
Pièces
Aucune pièce spécifiée.
  1. Ensure the device is off and unplugged.
    • Ensure the device is off and unplugged.
    • Remove the stylus from its port and set aside.
  2. Using a Phillips screwdriver, unscrew the 8 PH1 Phillips fasteners until you hear an audible click. The screws will not separate from the bottom cover when loose.
    • Using a Phillips screwdriver, unscrew the 8 PH1 Phillips fasteners until you hear an audible click.
    • The screws will not separate from the bottom cover when loose.
  3. Fix Kits pour batterie de MacBook
    À partir de $69.99
    Buy Now
    À partir de $69.99
    Buy Now
  4. The bottom cover is attached via several plastic clips located around the edges of the bottom cover. Using a plastic opening tool, gently pry the bottom cover from the laptop.
    • The bottom cover is attached via several plastic clips located around the edges of the bottom cover.
    • Using a plastic opening tool, gently pry the bottom cover from the laptop.
    • Work the plastic opening tool around the edges of the bottom cover undoing all of the plastic clips, as shown in the picture.
  5. Place your fingers around the edges of the cover and remove it. Place your fingers around the edges of the cover and remove it.
    • Place your fingers around the edges of the cover and remove it.
To reassemble your device, follow these instructions in reverse order
2 autre(s) ont terminé cette réparation.
Daniel Fernandez
Membre depuis le 14/02/2018
744 Réputation
5 tutoriels rédigés
Équipe
USF Tampa, Team S2-G3, Eyestone Spring 2018 Membre de l'équipe USF Tampa, Team S2-G3, Eyestone Spring 2018
USFT-EYESTONE-S18S2G3
4 membres
5 tutoriels rédigés
Ajouter un commentaire
Voir les statistiques:
Dernières 24 heures : 1
7 derniers jours : 9
30 derniers jours : 32
Total : 409
