Aller au contenu principal
Lenovo Thinkpad E540 WiFi Card Replacement
Ce dont vous avez besoin
  1. Lenovo Thinkpad E540 WiFi Card Replacement, Battery: étape 1, image 1 de 2 Lenovo Thinkpad E540 WiFi Card Replacement, Battery: étape 1, image 2 de 2
    • Push the battery release switches away from each other.
  2. Lenovo Thinkpad E540 WiFi Card Replacement: étape 2, image 1 de 1
    • Remove the battery.
  3. Lenovo Thinkpad E540 WiFi Card Replacement, WiFi Card: étape 3, image 1 de 1
    • Remove the single 1mm Phillips #0 screw holding the small plastic panel in place.
  4. Lenovo Thinkpad E540 WiFi Card Replacement: étape 4, image 1 de 1
    • Use a plastic opening tool to remove panel.
  5. Lenovo Thinkpad E540 WiFi Card Replacement: étape 5, image 1 de 2 Lenovo Thinkpad E540 WiFi Card Replacement: étape 5, image 2 de 2
    • Disconnect the two antenna cables from the wifi card.
    • Remove the single 1mm Phillips #0 screw from the wifi card.
  6. Lenovo Thinkpad E540 WiFi Card Replacement: étape 6, image 1 de 1
    • Remove the wifi card by sliding it out.
2 autres ont terminé cette réparation.
Timothy Sumner
Membre depuis le 02/14/18
1 040 Réputation
8 tutoriels rédigés
Équipe
USF Tampa, Team S2-G5, Nance Spring 2018 Membre de l'équipe USF Tampa, Team S2-G5, Nance Spring 2018
USFT-NANCE-S18S2G5
4 membres
8 tutoriels rédigés
2 commentaires
Pictures show battery is still connected to laptop.
Monte Christo - Réponse
There appear to be several different wifi cards available, with different PN numbers. Is it necessary to replace with the exact same PN number? Can these wifi cards be upgraded?
Thomas - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 28
Total : 2,974
