Aller au contenu principal
Lenovo Thinkpad T450s Bottom Panel Removal
Ce dont vous avez besoin
  1. Lenovo Thinkpad T450s Bottom Panel Removal, Battery: étape 1, image 1 de 2 Lenovo Thinkpad T450s Bottom Panel Removal, Battery: étape 1, image 2 de 2
    • Turn off device before starting
    • Flip the laptop upside down so you have access to the battery.
  2. Lenovo Thinkpad T450s Bottom Panel Removal: étape 2, image 1 de 1
    • Slide lock button 1 to the unlock position and gently slide away from your body.
  3. Lenovo Thinkpad T450s Bottom Panel Removal: étape 3, image 1 de 2 Lenovo Thinkpad T450s Bottom Panel Removal: étape 3, image 2 de 2
    • Slide lock button 2 to the unlock position and continue gently sliding until the battery is removed.
  4. Lenovo Thinkpad T450s Bottom Panel Removal, Lenovo Thinkpad T450s Bottom Panel Removal: étape 4, image 1 de 3 Lenovo Thinkpad T450s Bottom Panel Removal, Lenovo Thinkpad T450s Bottom Panel Removal: étape 4, image 2 de 3 Lenovo Thinkpad T450s Bottom Panel Removal, Lenovo Thinkpad T450s Bottom Panel Removal: étape 4, image 3 de 3
    • Flip the device over and lay it down with the underside facing upwards.
    • Unscrew all 8 screws. While they should not come out completely, in some cases, the plastic retaining washers may come off of one or more of the screws, allowing them to come out completely. - should this happen, look for a loose, tiny black plastic washer once the case is open. It's possible, in some cases, to reattach the retaining washer.
  5. Lenovo Thinkpad T450s Bottom Panel Removal: étape 5, image 1 de 2 Lenovo Thinkpad T450s Bottom Panel Removal: étape 5, image 2 de 2
    • Pry the bottom from the computer until it pops out.
    • In some cases, the vented side of the case may cling to the heat sink; appears to be adhesive. Take care when separating.
2 autres ont terminé cette réparation.
Hayden Hausman
Membre depuis le 01/17/19
625 Réputation
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 12
30 derniers jours : 31
Total : 3,683
